mpaniagua
Newby photographer
I suppose that with many kind of films, you can see the differences and possibilities of the films. On the other side, one can easily get confused with the many results you get. One have to remember that film kind is just one part of the whole equation. ASA speed used, which developer you use, choosen temp range, dilution rate, developing time, etc. has as much influence on the process as the film itself.
Using one kind of film allows you to see the grain, contrast, etc. of the final negative from the dilution, temp, time and developer you choose, so you can get a better undestanding of the whole process.
When I started using film (about 30 years) I used PlusX, just because everyone else I knew where using TriX. Later, I started using TMax 400 and some Ilford.
The final thought here is, YMMV, so try whatever route you fancy, make better sense to you and sounds more fun to you 🙂.
Regards.
Regards.
