Leica LTM New (to me ) Summitar 5cm F2.
lundrog
2:10 PM
Grabbed this today , had a stuck Aperture, managed to get it moving.
taken with my phone.
a Few taken with the Summitar 5cm F2, wide open. on my Fuji X-E2. Processed in Lightroom, slight contrast / brightness adjustments only.
with a small tube.
If you want to keep it in this condition get filter, not just cap. Lens optics are very soft. If you'll try to clean it and push little bit - scratches. Better to clean filter.
Adaptors from weird native thread to common filter size are availible:
http://www.ebay.com/itm/Leica-E39-F...925160?hash=item41aeb449a8:g:~UkAAOSwHaBWjn4k
http://www.ebay.com/itm/New-Adapter...cd12ced&pid=100005&rk=1&rkt=6&sd=252443978498
So if I nab the filter adapter, I assume I could use any modern uv filter that fits? What size fits the adapter?
Just measured mine and the average for a slip-on is 41.3mm which is an odd size. I've several lenses that take a 42mm slip-on lens cap and have tried them on the Summitar but they will need a lot of padding to fit nicely. That sticky thin felt might do it but...
Regards, David
