NEX5N ergonomics problem, a solution
3:50 AM
For those of us still upset with accidentally activating the poorly placed movie button, here is a clever inexpensive solution to solve the problem that Sony thus far refuses to remediate. Probably cost for the solution? Probably one thin dime. Very clever.
See: http://www.luminous-landscape.com/reviews/cameras/the_sony_nex_7_redneck_edition.shtml
I think a similar solution can be done to the inadvertent activation of the exposure compensation function activation by using a larger grommet placed around the circumference of the wheel and cutting the grommet even thinner before mounting.
For those of us concerned with affecting the resale value of our NEX5N or NEX 7, perhaps using a removable photo mounting adhesive instead of a permanent glue would be preferable. It may detach from time to time, but grommets are cheap.
I'm keeping an eye out for just the right self adhesive widget to do this to my NEX-7. I'm thinking one of those small stick-on rubber or plastic feet, possibly shaved thinner.
Thanks for that link. I actually tried the same solution with a small 6mm flat washer and some 3M double-sided tape. It worked, but a rubber grommet is a better idea.
I wouldn't worry about effecting the resale value - these are digital cameras, so they'll be "obsolete" within a year (although as any good RFF-er knows, obsolescence has no effect on a photographers ability to make a great image).
Thanks again.
SUGRU? I looked it up. It looks like a doable approach. I think molding it with a little tab to make it easier to remove would be a good idea. I don't like the idea of picking away at plastic or anodized camera body with a pen knife. Thanks for the suggestion.🙂
Sugru would work. I've used it on several occassions. It sticks, but can be readily removed without trace if need be.
I watched the Sugru video about removing the stuff. It can be removed easily from surfaces with your finger nail, but I would worry about using it on recessed buttons like the video button on the NEX5N. Residue might get stuck in the space around the button. So, I would go to a stationary store and buy some of those sticky back paper dots the right size and apply that to the button first. Then apply the Sugru. So if you have to remove it, it will come off and leave a clean button area.
