Nickel 50/2Voigtlander Heliar
spatek
5:59 AM
Hello - New to the forum and first post. I'm also new to the Leica screwmount world. Im shooting with a 1951 Leica IIIf with a Summitar 50/2 collapsible.
A friend offered me a 10th Anniversary Nickel 50/2 Voigtlander Heliar. Never used, with box (two box) and all the fixings for $500. Serial R057
I really know very little about these types of lenses.
Seems like a good deal to me.. Should I jump on this?
Thanks! That settles it.. I'm going to pick it up. Its a pretty thing to say the least. It apparently comes with an M adapter. So I'm assuming that if I get M6 one day I can still use this lens.
Thanks again!
It's a great lens and the price is right.
Not sure about it as a collectable. They seem to go in th $500 on a regular basis.
As an everyday 50mm it's nearly impossible to beat at $500. a beautifully rendering lens!
I loved the look but could not quite get used to the ergonomics mounted on my M5.
I prefer not a large lens but larger than the Heliar ( I use a ZM Planar now).
The Heliar is quite petite!
Cheers!
Love mine! Still available new for USD 799, so 500 is a good price.
Apart from that, that thing is sharp as an eagle's eye!
Thanks again!
Please post some pics of it on your III-f, and some of the results with it !
LF
Nickel Heliar 50mm f2.0, Bessa R3M. Fuji Presto 400. HC 110 1:60 11.5 min. Tokyo.
Thanks again for the info.
Luddite Frank - Here you go. I didn't want to take my summitar off as I have a roll of film in it. Here's the best I can do for now.
attachment.php
Interesting; to me the Heliar is a 1900's variation on the Cooke Triplet, modified again and fitted to my old Voigtlander Brilliant, so I guess they have revived an old name for a new lens, or what?
Regards, David
PS It must have been good as the Heliar version was about 40% dearer than the normal one in the 30's.
I have one, it's a lovely object to own. But more important it's a very good lens, I use it both on my Bessa R or on my M7. Don't let it go away!
robert
m7, heliar 50mm F2 anniversary edition, kodak ektar, CS3 + LR
It's a lovely lens and I should use mine more often....
I usually pair it up either on my M2, or even better, on my IIIf, which looks simply gorgeous!
Based on all the feedback here; I'm pretty stoked about getting some shots in with it. I went ahead and attached it mid roll. Might as well see if there is any leakage. The last image I posted disappeared, so I'll try again. Thanks for sharing your opinions and photos! :)
One of the attractive things about the 2/50 Heliar is that it is an "authentic" Heliar in its 5/3 optical arrangement. And the fastest such ever produced. In history, the Heliar has been popular in medium format and large format applications, up to f/2.8 aperture.
I think this nickel limited edition is easier to use than the bayonet-mount standard version, largely because it doesn't collapse, and the controls are a bit easier to feel. And you can use a 6-bit coded bayonet-mount adapter if you want to put it on a digital M Leica.
Hope and expect you will enjoy it! BTW, there's a dedicated hood made for it...
Pure lens p0rn, that Heliar in nickel. :D Love mine, can spend all day looking at it but it wouldn't get used if I did!
Shot it on a Ricoh GXR-M​
