Nikkon s 50 mm i've make A DISASTER!!!!
Stefcuoz
11:29 AM
Livorno- Italia
GOOD NEWS, REPAIR IT.
Help me my nikkor S 50 mm f 1,4 have blades out of order, i have dismount it now i don't found the regular order for reassembling the blades.:bang: :bang: :bang:
can some one help me????
Sorry... but it seems you'll have to send it for repair.
That, or wait for joe to post something. He once tried to do something with a 50mm Summicron and then found himself in a similar situation after a well intentioned touch on the blades with a little canned air.
Good luck! 🙂
I would think Fred or someone else on the Nikon NHS forum might be able to steer you in the right direction.
Ciao,
ci sarebbe un laboratorio a Pisa ... se ti fidi dei pisani 😉
Del.Pal. s.n.c. Viale Bonaini Francesco, 88 050 43362... sono cari assatanati, è un dato oggettivo non una considerazione da lucchese ...
in bocca al lupo!
Non-magnetic tweezer can really be of help at this point, especially 2 pair one angled. Above observation is probably correct, try the other blade orientation. Relax, have a beer, think about it, you'll get it right, its not too hard.
Ciao Luchese.....
Erano altri tempi quando del pal riparava gli obiettivi,ora sembra di entrare in sala operatoria e riparano, si fa per dire, cambiano tutte le schede, solo macchine elettroniche.
A parte il caro assatanato ed il pisano, concordo su tutto, penso che non ci sia nessuno da loro in grado di farlo, quanto meno ad un prezzo ragionevole....
Stefano
Un Livornese.
There are only two ways to arrange them. be patient, relax, and try carefully. If it wont work all you have to do is invert the order, and that´s it.
Do no desesperate, if you are angry, just go out for a run, and come back when you feel relaxed.
Ernesto
Victory
Victory
Thanks at all, after two night of passion now blades are at your right place.
2 beer, 2 wiskey, and other...😉 😉
Now i can sell it with any problem, lens is perfect , and is just on classified.
