.... If that's stupidity, then yes, people are that stupid. Take a look at basic photography texts today -35mm is now a "semiwide" or "normal" lens in most estimations.
I don't agree with that assessment, but you cannot deny the explosion in FX-capable wideangle Nikon zooms that hit 24mm or under (14-24mm, 16-35mm, 17-35mm, 18-35mm, 20-35mm, 24-70mm). On a DX body, a 24mm f/1.4 is a 35/1.4, which will make a lot of complainers happy.
And actually, considering that it is harder to make fast lenses as the angle gets wider and that the 24mm picks up about 5% in MTF at the center of the frame over the 28mm, it is arguably a better lens. In fact, if you compare the 24mm's numbers to those of the Leica 24/1.4 (assuming the MTF is measured similarly), you can see the market this lens is competing in. It
is the update to the 28. All it does is take into account the public's taste for somewhat wider lenses.
I loved the 28's performance, but it was a huge and heavy 42mm lens on my D2x and was a little too wide on my 14n. 28mm represents one of those funky angles of view that are too wide for people, are often too narrow for wide-angle architecture, and are just wide enough that you seriously have to worry about perspective tilt. You're never going to shoot a person with a 24mm, but you get more for the tradeoff.
Dante
As if a lens gets better the wider it is? I really hope that people aren't that stupid. If 28 mm is what you want, a 24 mm lens won't do it.
