Nikon 2.8cm f3.5
scorpius73
7:12 AM
I shot some frames with this lens. It's rather slow. But, the image quality isn't bad at all. This is from Kodak Tri-X @ ASA 400 souped in Rodinal 1:50 for 13 minutes.
I like this lens - it is a bit slow - but then you can handhold a Rf camera at much lower speeds than a SLR. It is not supersharp wide-open, the 28f3.5 VC in the SC mount is better at 3.5-4. Great 60's look though to the negatives - particularly a rather "snappy" combination like TX in Rodinal 1:50.
It is also one of the lenses that just looks right on a Nikon Rf.
I love W-Nikkor 2.8cm f3.5's vintage look. Compare to an SC 28mm f3.5, it's hard to find any weakpoint.
Even it shows good colors and well flare resistance.
496385e42bf4e
If you want to see more 2.8cm f3.5 pics, click below link.
http://sangin1122.tistory.com/tag/W-Nikkor%202.8cm%20F3.5
Thanks goliathus. I took a look at your blog. I like the images that the lens produces. When you say SC 28mm f3.5, do you mean the Voigtlander version? Thanks.
Tom A, I have been using Rodinal and Tri-X more often. It's a combo that I am liking more and more. I especially try to use it when I'm using older lenses. Just for fun, although I know Tri-X has changed its look over the years. I didn't have any issue with sharpness wide open. Maybe because I was focused at infinity.
I am a big fan of my black 2.8cm f/3.5 W-Nikkor. It's a great lens. I love how small and compact it is. I find it to be plenty sharp.
