Nikon 80-200 /2.8 users
De_Corday
Eternal Student
2:15 PM
Brooklyn via NJ
My one-ring 80-200 AFD is incredibly sharp, even wide open, except at 200mm, where it is annoyingly soft. Is this indicative of a problem? I regularly see reviews describing the lens as acceptably sharp end to end...
how sharp is for you?
what is sharp for someone could be .. not enough sharp for someone else....
if you can try to post a shot from your lens wide open at 200mm..
Mine is accettable also wide open ar 200mm ..... for me!
I have always understood this lens to be more soft at the 200mm point. I have one and think that is so, but I would say mine is not objectionably soft. Then again I probably do not shoot it at 200mm all that often.
Mine was excellent all across the zoom range at all apertures. I often used the lens with the TC-20EIII converter and it was still excellent. I say "was" because the autofocus motor failed and two repair shops said parts are no longer available. Based on that consideration alone, I would avoid buying a used 80-200.
The one ring 80-200 AFD doesn't have a focus motor.
Ronnie
I tested a Nikon 80-200mm AF-D that I was going to buy but sent it back because the image quality at 200mm f/2.8 was too low for my taste. I next tested a Nikon 80-200mm AF-S and purchased it because I was very pleased with its improved image quality.
Nikon 80-200mm f/2.8 AF-S by Narsuitus, on Flickr
Before the advent of AF, Nikon had a 80-200/2.8 ED zoom while Canon did not. I think that this was one of the main reasons for professionals to favor Nikon over Canon.
I have exactly the lens the OP is asking about, the one-ring AF "D". Last of the versions without tripod collar. Fantastically sharp, but I only very rarely shoot it at 2.8. I think any soft photos might be if I miss focus.
I use mine with a Kirk tripod collar. Its their earlier version, which I prefer to the one that came later which wasn't user-friendly if you wanted to shoot verticals. My Kirk collar is rock solid.
Nikon 80-200 2.8 Double Ring lens shot at 200mm f/5.0 1/640 (hand-held) ISO 100
Same lens but at f/8.0...I'm very happy with the performance of this lens...
