colker
In Rennes, France. It's hard to find something like that here.
Yeah but how do I check this screen?
Remove the finder, then remove the screen and then place it back according to the instructions.
How do you know you are out of Focus? Does it Look blurry in the Finder?
If I understand you correctly when you try to focus to infinity the infinity mark (∞) does a hard stop about 1mm from the 'distance index dot'.
i had the same problem as view range with an F2 , the mirror was out of allignment , minor repair , but I brought it to dealer.
Look this may be a silly question but you say the finder looks blurry. Does the image in the finder look blurry even when you try to focus on something closer? If so then the problem is your eyes and you need a diopter lens on your eyepiece to correct your vision for the F3 finder - these finders have a slightly negative diopter built in. Could it be that does not work for you in its uncorrected state?I got the new screen. It's better, but it still slightly can't focus to infinity. I don't know where else to look.
Yes
No, it just can't focus to infinity.
What dealer? How much did it cost you?
Ok maybe I found the issue, it might be that the focusing screen is a one that goes on a Nikon F, not a F3.
https://www.rangefinderforum.com/for...d.php?t=142668
It suggests there is an adjustment screw somewhere near the mirror to adjust its alignment.
Another thought occurs relevant to the F3. The F3 has a removable penta prism like many past Nikon pro bodies. Could it be that the penta prism is not properly mounted in place, thereby marginally throwing the body's geometry out and causing an apparent misfocus at infinity.
So this consideration begs a question - have you tried removing and refitting the penta prism or checking to see if the mounts are in good condition? Or if you can do so could you borrow another penta prism for an f3 and try focusing with a different prism on your camera body to see if that makes a difference. At least that would tell you if the problem is with the camera body or the prism.
That is strange. If the focusing screen wasn't the culprit, both the two screens should produce the same out of focus visible result when you look at the image in the finder, lock the lens focusing ring at infinity and aim the finder at something really located at infinity. If the first focusing screen was out of alignment in its metal frame, or wrongly installed, installing the new screen would have solved this out. It's very unlikely that two screens are both defective, and in a different way.I got the new screen. It's better, but it still slightly can't focus to infinity. I don't know where else to look.
There's no great mystery involved, because establishing the cause of the focusing problem just entails a basic understanding of how a single lens reflex works, and making a competent inspection of the focus accuracy in the correct order at the necessary locations—note that is locations, plural. The reason we are all still none the wiser is, quite simply, because the thread starter has tendered evidence that they lack this basic understanding, and has not taken the good advice previously offered, on board.To be frank I think most of us are a bit stumped as to why this is happening. Individual lenses not focusing at infinity are not all that uncommon but usually this is because someone has disassembled the lens for cleaning and not reassembled it correctly. Having several lenses all not focusing indicates a camera body problem - this is less common in my experience.
First of all you need to establish what needs adjusting.
Check the focus screen installation.
Work out what the film plane focus looks like. You will have a better idea of where the fault lies once you have verified the register of the body is correct.
What do yo mean?
To check the physical adjustment of the camera body film plane to lens flange, take a known good lens and mount it on the camera. Mount the camera on a tripod. Remove the film door. Place a piece of frosted glass or plexiglass or even scotch tape vertically between the inner film rails on the body. Frosted side toward the lens. The inner rails are one film thickness closer to the lens flange than the outer rails. Lock up the mirror. Focus your lens on infinity at a very distant object and look at the film plane with a loupe. If it is in focus, then your problem is with the mirror/finder/groundglass. If not, your problem is with the camera body. Repeat this with a few lenses to ensure that it is not your lens. If you don't start with this, you'll go around in a circle of testing the focusing mechanism while not ensuring the camera itself it calibrated. Once you have the proper infinity focus at your actual film plane, you can begin to mess with the groundglass/finder/mirror.
As was mentioned, it could be your mirror, your eyepiece, your mounting of the groundglass condenser or even the prism itself.
Phil Forrest
God knows I've spent countless hours doing my best over the years to help members with their camera problems if I could—but if someone won't, or, can't, recognise good advice and run with it, then, there are limits to how much I can assist, and, I suggest others, also...
