Dwig
How's the battery life on the FE? What kind of battery is it?
All of the FM/FE family use the same batteries. The original "stock" battery set was a pair of 1.5v S-76 silver oxide batteries. The cameras all have their own internal voltage stabilization and will work with any power supply over about 2.1v total and under something in the 12-15v range.
It's quite common to use S-76 size alkaline substitutes and a single CR1/3N Lithium 3v battery will work very well and has the advantage that is doesn't leak when it dies. Nikon offered an external battery pack for the series (fit the F3 as well) that used a pair of AA alkaline batteries and had no circuitry. It merely wired the cells to the camera's battery compartment.
Battery life is quite good in all of the series with the exception of the original version of the FM when used on the MD-11 motor drive. This combination would allow the user to easily lock the meter in the on position with no built-in timeout sleep function. The later MD-12 motor resolved the issue and a reworking of the body's switching (moved release lock and switching to the wind lever instead of a collar around the shutter release button) reduced user error.
