NX100 not working with adapter. Help!
thaung
10:50 PM
I having som serious problem getting my NX100 working with a M42-adapter. It just keeps saying "No lens" when I press the shutter release button. No matter what mode i put it in "P, A, S, M, Movie) helps. I have gone over the settings a hundred times and nothing seems to work.
When I first got the camera it had firmware version 1.00, I have since upgraded to 1.02 but it did not help either.
Is anyone else having this problem? I can´t imagine Samsnung being so careless as to make the camera not work without a NX-lens on.
On the Sony Nex there is a menu option to 'operate shutter without lens', I would have thought there would be a similar option for the NX - its just a matter of finding it and setting it. Can't help you any further as I haven't got an NX. You will only be able to use Manual and Aperture priority exposure modes.
Unfortunately the camera doesn´t seem to have the option of "fire shutter without lens". I have seen this function on many other cameras I have owned but this seems to be missing it.
I have also tried to "jiggle" the adapter without any luck.
I´m all out of ideas and really confused as I also have played a bit with a NX10 and on that camera with the same adapter it works just fine. Without the need to set anything special in the settings menu.
