Calzone
Gear Whore #1
- Local time
- 10:31 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
My “Evil” matte-black conventional reel was delivered, and it is a beauty.
The lever drag is new to me even though I have fished with Penn Internationals offshore, and the styling of this reel is for offshore. Basically I have used lever drags, but I never owned one.
The narrow spool designed for deep water jigging in the Pacific also serves me well for easy line laying for surf fishing. Then this drag is stout enough and strong enough to fight tuna.
I was concerned with how this would balance with the new Fenwick rod which at only 7 feet in length marginally could be used as a beach rod. I have the 10 foot surf rod, but I don’t know if I want to buy a Van Staal reel because this would not get used on a kayak.
The Fenwick rod has a heavy fast action that is well suited to casting heavy lures, plugs and jigs up to 3 ounces. The new Accurate narrow spool just feels right on this rod. If I loaded the rod with 50 or 65 pound braid it could be used for fishing school sized Tuna in the 50-80 pound range.
My intent is to load it with 30 pound braid for inshore fishing. Still a good rod and within its designed usage. With thinner line I gain casting distance, and pretty much the 7 foot length is not too bad of a handicap.
Now my thinking is getting an accurate BV-300N-SPJ, pretty much a smaller version to have a lighter setup with a moderate action specialized for lighter weight lure 1/2 ounce to 2 ounces. I basically want/need a rod with a wimpy tip that also could be used for bait fishing. I would want a longer rod in the 7 1/2 to 8 foot range.
The SPJ suffix is a reel with the longer handle, ergonomic knob, and no clicker. Pretty much the longer handle and knob once used or tried out pretty much spoils you, so I jumped ahead and started with this version.
Now I’m thinking of going with a rod in the realm of light moderate action that would use 20-40 pound test lines. Again I would load it with 30 pound test, but one rod would be heavy and have fast action, and the other would be light and have moderate action.
On the lighter rod the wimpy tip would kinda collapse and in effect when fighting a fish it would become about the length of a shorter rod. These long-fall jigging rods are designed to keep slack out of the line when you pitch the jig by violently raising the rod tip and then lowering it.
Somehow I overpaid my NY State taxes. I got a pretty big check in the mail today.
Cal
Cal
