Oh my I think I have another leak!
RBruceCR
3:06 AM
Since we are in Costa Rica above the Ecuator, the sun moves from East to West on a Southerly angle.
The following picture was made at 1:00 PM pointing towards the Southeast. The sun was probably on the right hand side pointing towards the camera. My camera is a mid 1960's Mamiya Standard 23.
The following picture shows a leak in the lower right hand side corner, which backwards means the upper left hand side of the frame. Which coincides with the position of the viewfinder window!
photostream
https://www.flickr.com/photos/rbruce63/14795131460/in/photostream/
Could there be a leak of light from the rangefinder assembly coming in from the viewfinder?
I had a nasty leak that allowed some light to damage pictures before. I had the tech repair the lens bayonet release button and solved the problems by leaving a black masking tape on top of the button before that!
I hope you can chip in!
Regards,
I would vote more the upper left of the seal on the removable back causing the light leak. I got a kit of foam from someone in Japan, it was cheap and easy to use, and mailed direct for Japan. Put your black tape there.
I had the backs repaired with that same foam from Japan...
Were you able to see the picture? I can't post them directly on the forum.
