Old lenses with beautiful bokeh - Ideas?
I almost exclusively shoot old lenses with unique signatures. In large format, a lot of Petzvals and pre-war soft focus lenses. In small format here are a few I like:
Pizar 25mm
Dallmeyer 25mm F1.9
Pizar again
Dallmeyer again
Dallmeyer 25mm F1.9
Dallmeyer again
I especially like the Dallmeyer shots. Very nice.
Peter from the samples of the original post I take it that you may, above all, look for lenses that do "doughnut" shaped bubbles with a thinner outer ring as created by mirror tele lenses.
the Nikkor-S.C f1.4 5cm ( I downed clarity in LR a lot, otherwide the bubbles and their outer ring would have been quite a bit more pronounced, too harsh for my taste )
Untitled
by andreas, on Flickr
Canon LTM f1.8/85 can do it ( though bokeh is smooth when stopped down )
Harley Davidson
Takumar f1.4/50mm also "can" do it
Bamboo
concerning Canon LTM, the f1.4 is more contrasty then f1.2 and f1.5, but neverthless the f1.4 imo seems to produce bokeh that isn't dissimilar to that produced by the f1.2
Untitled
my f1.5/50 has very low contrast, lovely, and, as imo all 50mm Canon LTMs, not bubbly:
Untitled
for a low contrast but smooth bokeh Olympus Olympus OM F.Zuiko Auto-T f2 85mm, that is the first version with single coating
offering incense during Vietnamese New Year
though later MC version should be fine too, other smooth bokeh, rel. low contrast include Om Zuiko f2.8/100mm,Minolta MC Rokkor f2.5/100mm, Super Takumar f1.9/85mm...
very fun, individual bokeh, cat's eye and swirly, for rel. wide angle, Pen-F Zuiko f1.8/38
Happy Lunar New Year
different but fun too, Canon LTM f1.8/35mm
Untitled
similar: MC Rokkor-PF f1.4 58mm
Untitled
Kuuan, I would not say that I am specially or specifically looking for bubble/dohnut bokeh. But it is one "option" as I have written elsewhere in this thread. While many decry it (and it can be over done) I like it when it is done well and it is not "over the top". And the shots you have shown, particularly the first one do look good to my eye. Probably my favourite bokeh is the very smooth melty bokeh which smooths out into pastel colors with no defined shape. Like your Canon 50mm f1.5 (always one of my favourite lenses on all counts.)
Kuuan, How did you do that with the Super-Takumar f1.4 50mm. I've used mine since 1969 and never had those rings? What's the trick?
I wished I could say that. Generally I consider bokeh of the 1.4/50 Takumars as quite smooth. Soup bubbles are possible though, the distance of the oof highlight to the focus plane must be "correct" and I'd say they are more likely with the later S-M-C than with the earlier Super Takumar.
btw. an interesting article about bokeh: https://www.bhphotovideo.com/explora/photography/tips-and-solutions/understanding-bokeh
Thanks for the article, I have a Thorium f1.4 which has to be cleared every couple of years. But as it is Christmas time I may try to get some 'soap bubble' bokeh. There are lots of lights around my house now.
Thorium Cure by John Carter, on Flickr
for pastel colors and smooth bokeh and lenses I have experience with early Takumars, that is preset and Auto Takumars, come to my mind.
The rare "Sonnar" f2/58mm may even be a bit similar to the Dallmeyer shown?
Untitled
Untitled
cosmos
but also the cheaply available Auto Takumar f2/55mm, the medium priced Auto Takumar f1.8/85mm and Super Takumar f1.9/85mm, preset and Auto Takumar f2.8/105mm, preset 3.5/135,
one by Auto Takmar f2.8/105mm
passiflora
generally, early, single coated lenses,
guess you may like this one, Komura LTM f3.5/100mm, early version
Untitled
wow, nicc set up for clearing the lens. My S-M-C Takumar that had been quite yellowed cleared up simply because I used it very much in tropical countries with strong sun, it used to be my most used lens for quite a few years. Christmas light make a great subject for bubbles 🙂
this is pretty much the only soupy bubbles that I have taken with the ( later 7 element ) Super Takumar f1.4/50mm
Tuk Tuk
My Super-Takumar 50mm f1.4 was in the tropics for 3.5 years, I still think it was the thorium that yellows. Easy to clean though. I did put my f1.4 on an DSLR tonight and played around with Christmas Tree lights. I did get some soapy bubbles, I'll have to work harder to equal yours. Thank you and good shooting.
Untitled
Untitled
cosmos
passiflora
Untitled
You are right about the early Takumars. Lenses like the 55mm f2.2 (and f2) auto Takumar, the 85mm f1.8 auto Takumar, the 105mm f2.8 Auto Takumar and preset and the same for the early 135s are easily amongst my favorites.
And I was surprised at how many of them had a Sonnar design or a derivative of that optical formula till I looked at this page http://www.klassik-cameras.de/Pentax_Takumar_e.html.
I feel a little sheepish - people keep coming up with lenses I already have and to extent take for granted. But the grass is always greener I suppose. BTW some very nice photos in your set.
I feel kind of sheepish - the
The site you linked has been my main reference for Takumars!
Pentax was pushing the development of SLRs in the 50s, no other maker produced as many interesting SLR lenses that early on.
I believe that pretty much any preset, that is early, short tele may fit your request, could be "no names", with a bit of luck one may find such for very little money. E.g. I have a preset Tele Kominar f3.5/135mm and a "Berolina" f2.8/135mm that should, haven't use much either of them though and can't share good samples, here is what I have:
the Berolina 2.8/135
Untitled
the Tele Kominar 3.5/135
city bloom
I believe that pretty much any preset, that is early short tele may fit your request, could be "no names", with a bit of luck one may find such for very little money. E.g. I have a preset Tele Kominar f3.5/135mm and a "Berolina" f2.8/135mm that should, haven't use much either of them though and can't share good samples, here is what I have:
Untitled
city bloom
Yes, I must admit recently I too have been buying some old lenses - mainly 135mm lenses sold with the names of long defunct lens marques (mostly ones i have never heard of) on their name plate. I was aware that some of these would be lenses actually made by 1st or second tier lens makers and put out there to be sold by other companies. I was also aware that some would be Sonnars - one of my favourite older lens types for image quality and nice bokeh. And this offered promise.
A few I purchased recently were a 135mm f3.5 "Force" lens in LTM mount which looks pretty well identical to the Super Acall 135mm. These are true 135mm long focus lenses not telefphoto lenses in the technical sense. My research suggests this lens was sold under at least half a dozen names.
Another I picked up was also a 135mm f3.5, this time in M42 mount and with preset diaphragm. Its name is Titar but apparently was according to my research sold under perhaps a dozen other names. It is solidly built and a few quick shots so far look hopeful.
A third I bought (for $5) is marked 35mm f2.8 with the name Mosler. It turns out Mosler is (or was) a USA based security company and this a lens appears to have been bought in from some company to fit into one of their security TV cameras. Its build quality looks reasonably good (in line with other 2nd tier makers of the time) and the few shots I have taken with it again look promising. When I can find them, particularly if I can pick them up cheaply I will continue to buy them and try them out as I get the chance.
This is one of my own images shot with a Helios 58mm f2 (optically a copy of a pre war Zeiss Biogon lens). I have to say that I love the rendering of these old Sonnar lenses - both the bokeh which is acceptably soft and billowy and the subtle gradations in tone which I think is the real mark of many Sonnars. I grant you that this is not especially sharp however, though I put that down to me more than the lens. Never the less, a lens perfect for portraits of old ladies and young cats.
EDIT: See my correction above - actually a Jupiter 8. My old fart brain fade........
If you want the Trioplan bubble bokeh without the Trioplan price try to find a Tomioka (Rikenon, Chinon, Revue) 55mm f1.4 lens. It's very close to the Trioplan. I just sold a Rikenon in excellent condition for $89.
