johny
Does someonenknow how thick the light sealing should be for the canonet gIII ql17 to replace? is 2mm fine?
The Olympus RC has quite a bit of pincushion distortion - can't stand it.
The Revue 400SE aka Vivitar 35ES is not a bad camera (I've got both). Only difference is that the Vivitar has a better finder - the one in the Revue distorts quite a bit. Really good lenses on these cameras but all in all the built quality is not up there with the Canon or Olympus models. I have a soft spot for these 70s fixed lens RFs and owned quite a few of them but at the end of the day I don't think there are worth what they are selling for on ebay at the moment. Personally I wouldn't spend more than 30€ on any of those cameras (except the SP maybe). Here in Germany you always get good deals on this type of camera on flea markets etc. - don't know about your place. If you have to go the ebay route you might consider a model with a f2.8 lens as they're going for next to nothing compared to the f1.7/f1.8 ones.
Of the cameras mentioned, the SP is the best. It is a very well made camera, with a great performing lens. The quality of materials is also good, especially the glass. The weakest point of the Canonet QL17 is the low quality of the glass and coatings, which are very susceptible to fungus, and haze. I am always on the lookout for good Canonets in Japan, but only about one in five that I find has a decent lens.
If you don't mind a more vintage style rangefinder camera. the Konica IIIA, Olympus 35S, and others are full manual options, with great lenses, and no need for batteries.
The weakest point of the Canonet QL17 is the low quality of the glass and coatings....
My size comparison camera for a 35mm camera is an 80 year old Leica II with a collapsible Elmar. It's a compact 35mm and even though it is 80 years old - it is still serviceable.
With the Konica S2 and Olympus 35 SP you definitely get what are hands down simply superb lenses.
You also get a camera that is similar in size and heft to a more modern, compact SLR, like a Pentax MX. The Pentax MX may even be a bit smaller.
The QL 17 GIII, 7S II and the troublesome 35RD from the 1975 era are definitely more compact - but if you are buying a fixed-lens 35mm RF from the 1970'ies over the internet - it will be like buying a lotto ticket. There will probably be issues.
Bottom line: the build quality on most fixed-lens, 35mm RF cameras from the mid to late 1970'ies is not as robust as an SLR from the same decade. With the plethora of used film SLR's currently for sale - a compact SLR may be the better buy in the long run.
Just a thought from the owner and user of a recently serviced Olympus 35RD.
Johny - The link below may be of some use.
http://www.kyphoto.com/classics/seal/Canon_CanonetGIII.pdf
Best Regards,
THank you! In this tutorial they use 1.5mm, 2mm and 3mm thick sealing. But i have found only 1mm, 2mm and 3mm thick sealing selling from japan, special for camera sealing. There is no 1.5mm.
