R
ruben
Guest
Recently someone at RFF wrote about having no problem with the Oly 35sp Exposure Values scale, as he remembers each aperture/speed combination of each EV.
As by comparizon I am a dummy, I offer the following method to exploit the viewfinder scale without taking your eye off the viewfinder. The method may help low light shooters ready to stay at a fixed speed, let say 1/30.
a) set your lens speed ring to 1/30 and your f/stop lens ring at f/1.7. This will be your basic set-up.
b) If the needle at the viewfinder scale points 6 or below - you cannot shoot, as you doesn't have enough light.
c) If the needle points 7 - just shoot. EV 7 is equivalent to to f 2 and 1/30
d) From 8 to 12 you just move 1 click per each EV shown by the scale, without needing to take your eyes off: if the scale shows 9, then you know you have to move your aperture ring just two clicks from the set-up position.
Ok, this is not the same as the luxury viewfinder scales of the Oly RC, but something is better than nothing.
Ruben
Ruben
