Olympus 35sp repair
Avi999
4:09 PM
Israel
Hello all
I need your advise and help concerning my new Oly 35sp.
It's shutter is stuck and self-timer is not working.
Can anyone please point me to a site or an on-line manual
of shutter repair for this model.
I'll appreciate any advise
thanks
Avi
I haven't done it on either of my SPs, so I can't comment from experience. You should probably be able to access the shutter by removing the trim ring, and aperture and shutter speed rings. (I have an Olympus Auto Electroset with a Seiko shutter of older vintage, I think it's similar.) That's not a hard job, just make notes as disassemble; I also keep parts from each assembly in individual plastic bags, i.e. Ziploc or similar.
There's some info in Japanese here and some info on leaf shutter servicing in English here. Hope this helps.
I don't have much experience withthe 35SP but what is the problem with the timer? If this is stuck, you won't be able to release the shuuter. A common problem on the Canonets. Get the timer sorted and then if the shutter doesn't work, you will need to think about cleaning the blades.
Kim
35sp repair info
35sp repair info
Thanks Trius and Kim for your replies.
I'm kind of surprised to find so little repair info
on 35sp, I thought it was a popular one among RF fans.
As for the timer, lever goes from one side to the other
and returns immediately with a spring movement. it does not
catch on the end nor it sounds any ratchet sound.
Avi
Can anyone please advise on how close is the
35sp shutter design to the 35rc shutter design?
I ask this since for the 35rc it is possible to find repair manuals
and for the 35sp I couldn't locate one.
thanks
Avi
The shutter on the RC only goes down to 1/15, while the SP shutter reaches 1sec. The RC shutter is controlled by a dial on the top plate, rather than a lens-mounted control ring. Given those differences, I would doubt a repair manual or guide for the RC would be much help with the SP.
thanks trius
can you please name another 35xx camera that its
shutter design is close or the same as the 35sp ?
thanks
Avi
Trius said:
Avi: Try this page which gives the procedure for disassembling and fixing/adjussting the Seikosha SVL.
hello Trius,
pens are nice, but I don't see any connection to the shutter 😉 😉 😉
probably wrong link, please update
(did you mean for daniel mitchell's page?)
thanks
Avi
Aaargh! Yes, I meant Daniel Mitchell's page here. Obviously you've seen it before, but I'm posting it for clarity and for others who may not have found it.
I have a question about the operation of this shutter in my Auto Electroset, but I'll start another thread.
Earl
