250swb
Tests done by individuals can be manipulated. And in this particular case, manipulation is the name of this person's game.
There is no reason whatsoever that certain parts of the white napkin shot by the (supposed) D3 have selective blowout. Upon close examination I can only come to the conclusion that the manipulator selectively applied the dodge tool in photoshop in order to make it appear that the D3's sensor has less DR than the E-P1 sensor.
The lower visible part of the white napkin easily shows it. Comparing that area to the same section shot by the (supposed) E-P1, it is easy to spot where and how the manipulation took place.
Poor guy. He must have bought Olympus stock.
Tests by individuals can be manipulated, but in this case I think all he is doing is recreating the tests done by Amateur Photographer magazine April 11th 2009 issue. In this controlled magazine test they found the Panasonic G1 (same sensor) had a higher resolution when compared to the D3 and D700, and did so with either a common non telecentric test lens, or the Pana kit lens.
The audacity that Olympus or Panasonic with their m4/3 sensor can achieve a small victory over the Nikon D3 does annoy people. Some say it is tantamount to creating a 'myth', but considering how many genuinely unfounded myths people like to put about regarding 4/3 sensors it is hardly scratching the surface in balancing the discussion.
Steve
