Olympus OM-1 Battery
I had mine converted to use the SR44 button cell. Adjusting the ISO will give you good results in good light but i noticed in mine (before conversion) that in very low light or in very bright conditions there was an error of +-1 stop.
OP: I have used zinc-air batteries in a variety of cameras, included unconverted OMs, rangefinders, etc. You do need the proper spacer (normally an o-ring as mentioned,) which, inevitably seem to get misplaced/lost. Also, the zinc-air batteries do not last nearly as long as silver-oxide batteries. If you have multiple cameras that use the 1.4v zinc-air batteries, when I pick up a camera that has not been in rotation, bam, the battery is dead.
If your OM has not had a professional CLA within the last several years, you should consider it. Have John at zuiko.com do it and he will convert the metering system and battery chamber to take commonly available and cheap silver oxide SR44 batteries.
Metering with an alkaline battery is NOT recommended - the discharge curve is simply WRONG for the OM and as the battery depletes your exposures will progressively be off even though the meter display seems to be behaving normally.
The nice thing about the OM-1 is that it is fully operational without a meter, so you can use an external meter or Sunny 16 if your battery is dead or you don't have a battery.
