artears
I am interested in trying om lenses on a leica body, however, I could only see one adapter from novoflex, which, I believe, is not rangefinder coupled. Some search turned out that cameraquest used to sell one with that feature bringing up 50mm framelines. I might use a 90mm om lens on the body and I do not care much about 50mm lines, however rangefinder coupling is important at this focal length. The adapter from cameraquest seems to be discontinued though. I am wondering, if there is another adapter for om->leica m enabling rf coupling. I would appreciate if you could provide some information about this.
radi(c)al_cam
Maybe you will find a used one.
Recently, I have seen a sibling of the item you want to have, look at eBay no. 300380319465 -- "wrong" mount unfortunately.
Have you considered a separate rangefinder like a Watameter?
I am very comfortable with the Novoflex adapters in combination with a Watameter if necessary.
photokalia
I was searching for the same thing recently, and you are right. The Novoflex is the only option. In the end, I gave in and went with a cheaper option, OM to EOS mount. Though I'd much rather use the lens on my M6!
You can check out this thread for more info.
http://www.rangefinderforum.com/forums/showthread.php?t=83670
rodt16s
I remember looking at these. Not coupled, but ideal for WA and zone focus.http://www.srb-griturn.com/other-lenses-on-leica-m-rangefinder-196-p.asp
squirrel$$$bandit
I don't think you could get coupling without major work on the lenses themselves; ie., putting them in a new housing.
ferider
The one you see in my photo that you attached is coupled (the adapter has a second focusing helix), and brings up 50mm framelines. Sold by Stephen but discontinued. I would not feel comfortable focusing a long lens with it though.
Also, as much as I like my OM Zuikos on my OM1 and OM4, there are lots of 85/90mm M/LTM-mount lenses out there, with better IQ than OM lenses, and costing not much more than the adapter.
gliderbee
Not coupled, but I have a Zuiko to LTM adapter; if you combine that with a LTM to M adapter, it should work, I guess.
I didn't try this, but if useful, I'm willing to give it a try.
Stefan.
Stefan.
squirrel$$$bandit
Wow--didn't know that existed.
radi(c)al_cam
John, have a look at eBay, item no. 300380319465 -- it's a Pentax-K mount version of the weird adapter with this feature.Wow--didn't know that existed.
squirrel$$$bandit
Oh yes, that I've seen--it's a match-the-setting type of situation. I thought we were talking about the actual focus ring on the lens being coupled to the rangefinder cam.
radi(c)al_cam
Yes, John -- you recognised my nick name in another thread
http://www.rangefinderforum.com/forums/showthread.php?p=1266445#post1266445
fantasy diy scale focus to rangefinder conversion
-- a very similar challenge with quite the same issues, so to say seen from a different point of view(finder).
artears
Thank you all for your valuable comments. It seems like the adapter from stephen is the only one and my only option is to look for it used...
May I ask why you don't feel comfortable focusing with longer focal length lenses with this adapter? I was considering of a tokina 90mm f/2.5 lens with it. So, the focal length I am looking at is 90mm, not a wider angle. I am pretty sure that this lens will provide a leica-like quality, this is why I am considering such an adapter...
DNG
Film Friendly
I want just the opposite! I want to use my 50/1.1 Nokton on my Pentax! There must be one... I'll pay for a hack of the two adapters mounts, if it will work.
Steve M.
I don't think an M mount lens will work on an SLR camera due to the lens to film plane issues. The mirror hits the end of the lens. To my knowledge, only the R Leica lenses, being designed for an SLR already, will work The good news is that w/ the Leitax adapters you can put Leica R lenses on Olympus, Nikon, Pentax and other cameras. I have a friend that had the lens mount removed from a Canon New F-1 and a Leica R lens mount installed on the camera years ago. Pretty neat. I use my Leicaflex SL for 50mm shooting, and a Nikon N6006 w/ Leitax adapter for 90mm shooting. Best of both worlds.
Trius
Waiting on Maitani
I considered the OM->M adapter for my Zuiko 21/2. At that focal length, zone focus is just fine, and it's one of the best OM lenses. But I agree, for other applications, buy an LTM or M lens. Better yet, use a 50 on an OM ... radical thought! An OM body feels and handles a lot like an M.
artears
21 f/2 supposed to be a very good lens. I have never seen it in person though
I can also use om lenses on my E-3, however I was curious about to see/test them on a leica
ferider
3 Reasons, Artears:
1.) the 50mm frameline
2.) the adapter works by setting it focusing via rangefinder, then transferring visually the distance you read to the lens. Or vice versa: you prefocus the lens, transfer to adapter, and then move until the RF is in focus. For normal portraits this is a slow process, and I think not accurate enough (very small focus changes will give you a picture out of focus).
3.) If I remember correctly, the adapter was around US 250 new. The picture below shows my Vivitar Series I 90/2.5 (Similar to your Tokina?) in comparison to the Hexanon 90/2.8, arguably one of the best optics for Leicas around, very nice bokeh (similar to the "Bokina"), very sharp, and, so much smaller .... A good M-Hex 90/2.8 will cost you around US 400 used.
I bought the adapter to use it with a 21/2 one day - which hasn't happened yet. I have used it with the 28/2. But there again, the CV 28/1.9 (around US 300-350 used) produces very much better image quality (resolution & distortion).
Hope this helps. Best,
Roland.
artears
Thank you very much for the detailed reply. I really appreciate it. Looks like I rather not pursue this adapter and try to find a hexanon 90mm f/2.8. That would serve me much better I guess. Smaller and less problems with focusing. Due to funding issues and not being sure of if I will be using this focal length too much on a Leica M8, I am not looking at any leica offerings now.
Is anyone here interested in parting with his 90mm hexanon f/2.8?
