May need to be cleaned
I had the same problem and it turned out to be some corrosion on the contacts under the orange button. I carefully pried up the button, which is glued on, then cleaned the contacts, which did the trick.
Instead of gluing the button back on (because I couldn't find the glue) my wife gave me some sticky wax to use. Works great.
