Chriscrawfordphoto
Real Men Shoot Film.
Christopher (or anyone)...
Can you provide a little education here. I just recently started using an OM2 (and loving it!), and I'm pretty sure that it has in it the stock screen. I'm OK with that, but if there is a significant advantage to swapping for another screen I would love to hear about it. I've had this screen out of the camera to clean out the dust, so doing a change would be no problem.
Cheers...
Rem
The 2-series screens are only for the OM-2s Program, the OM-3/3Ti, and OM-4/4T/4Ti models. It cannot be installed in an OM-2/2n or an OM-1/1n because its tab (that you hold to install it) is too wide for the space the OM-2 provides for the tab to sit. Some people break the tab off so they can install them anyway. I wouldn't bother. The chance of damaging an expensive and RARE part is too great, and the brighter screen messes up the OM-2 metering system. The OM-2 has CdS cells in the finder for manual metering and also to indicate the approximate shutter speed you'll get with autoexposure. The actual autoexpsure speed is determined by the Silicon Blue Cell in the bottom of the camera that reads off the film and fist shutter curtain. So, with a 2-series screen your OM-2 will give accurate autoexposure results, though the speed indicated in the finder will not be what you actually get. In manual mode, the camera's meter will be off.
