OM2-sp opinions
Sparrow
4:31 AM
OM2-sp, any opinions or issues? How dose it compare to the OM2
Saw one at the weekend that was like new…….and I’m tempted
I've had one for years.
Wonderful.
Especially with the wide zoom 28-48.
There's some sort of fault with all OM2SP's circuits that they need new batteries about once every month or so.
Thanks Jon, I knew I there was something, just couldn’t bring it to mind, do they drain even when they’re switched off, or are they just thirsty
I think it's a great camera (I have four, plus OM-2's, 1's and 4's). Mine tend to eat batteries also, although not once a month (every 6 months?). It handles more like the OM-4(t) series than the earlier ones. If the price is great, go for it. I have picked them up on EBAY for quite a bit less than $100, all in great condition.
I have had a 1972 om1 from new and use that for longer lenses, my om2 was stolen a few years ago and I wasn’t going to bother replacing it; then at the weekend I found this, it’s a bit expensive but it looks unused………and you know about temptation
A great SLR. The battery drain problem is much discussed but not as often found. Mine uses one set a year. Once mine locked up, requiring a $50 fix to unlock the wind gears, and I was told this is an occasional problem with some. Watch out for a collapsed rewind button.
The viewfinder with a "2" series screen gives the most lovely image in the OM world, maybe the best of any SLR. It's bigger than that in the OM-3/4, which is set back some to make room for the dioptric correction gear. You may spend as much on the 2 series screen as you do on the camera!
For what they are going for these days, a fabulous value.
Much more modern than OM-2, the LED in the viewfinder is like those in OM-3/4, a far departure from the simple needle indicator on OM-2.
I wouldn't pay too much for it. If you have the itch for spot metering, go for the much more reliable and featured OM-4. If you like classics, the OM-2 or OM-2n is more so.
I would be using it just for telephoto stuff, I expect in manual mainly.
I lost all my Oly stuff in a burglary a few years ago, but the 28 and 85 f2 I would be adding a 100 and perhaps a 135
My batteries last for weeks, but not months.
Not a major problem, as the batteries are very inexpensive.
Perhaps they fixed it in later years? Although I don't recall it was in production for long.
ferider said:
Go the extra step and get an OM4. You will not regret it :evil:
That shouldn’t sound anything like as sensible as it does, with luck it will be sold by the time i go back
:rolleyes:
