ORWO A03 developer
tho60
6:56 AM
I have found a small bag of ORWO A 03 developer, for 500 ml solution. Developing times are, according to the inscription on the bag, between 6-8 minutes. I did a dab test which shows that the developer still works.
Does anyone know something about ORWO A 03 developer?
It was a standard developer in DDR times. You can use the 500ml several times without re-generation so it is simple in use. However the stock won't last very long.
If I remember correctly, Orwo A03 is the equivalent of Agfa Refinal.
I've actually found that the stock solution of A03 does last a while if stored in dark, full glass bottles. It goes off much quicker if used of course.
