OT: Tool guide
kiev4a
1:31 PM
Subject: Useful workshop tools & their purpouse
Hey gang, now that winter is setting in, it's time to start working in the
shop, repairing all those little devices that need some overhauling. With
that in mind, I thought I'd share some of the real uses for some of your
shop tools! I'll bet you'll agree with some of these tried and tested (by
me) functions. Hope this helps your selection of just the right tool for
the right purpose? Jim
1. DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
2. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls and
hard-earned guitar calluses in about the time it takes you to say,
"Ouch...."
3. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
4. PLIERS: Used to round off bolt heads.
5. HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
6. VISE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the palm of your
hand.
7. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside a
wheel hub you're trying to get the bearing brace out of.
8. WHITWORTH SOCKETS: Once used for working on older British cars,
motorcycles, and (Vi counts), they are now used mainly for impersonating
that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
9. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new disk brake pads, trapping the jack handle
firmly under the bumper.
10. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile
upward off a hydraulic jack handle.
11. TWEEZERS: A tool for removing wood splinters.
12. PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
13. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-do off your boot.
14. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes
and is ten times harder than any known drill bit.
15. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of bolts and fuel lines you may have forgotten to disconnect.
16. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the end
without the handle.
17. AVIATION METAL SNIPS: See hacksaw.
18. TROUBLE LIGHT: The home builder's own tanning booth. Sometimes called
drop light, it is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under cars at night. Health benefits aside, it's
main purpose is to consume 40-watt light bulbs at about the same rate that
105-mm howitzer shells might be used during, say, the first few hours of
the Battle of the Bulge. More often dark than light, its name is somewhat
misleading.
19. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used, as
the name implies, to round off Phillips screw heads.
20. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts
last tightened 70 years ago by someone at Ford, and rounds them off.
21. PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
22. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
23. HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate expensive parts not far from the
object we are trying to hit.
24. MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well on
boxes containing seats, chrome and plastic parts.
25. Shop Vacuum: A large noisy roll-around device used primarily for
causing the permanent disappearance of very small exquisitely expensive
parts.
26. Vinyl tape: a black linear flexible adhesive product used to bind
little squares of paper towel over fresh cuts and/or abrasions (see: a.,
b., c., e., p., q., s., v., & x., above).
Good list! I note that most of the tools mentioned are mechanic's tools and thought I'd note that wood workers have somewhat different tools for similar uses.
And some specialized tools of their own.
Table saw: Large electric tool used for fingerprint removal and making sure the anti-coagulant drugs are working.
Wood lathe: used for throwing large VERY sharp, heavy cutting tools in unexpected directions. A secondary use is to set petroleum soaked cloth on fire and throwing the burning mass in unexpected directions.
Planer-jointer: used for smacking the chins of small children holding the end of heavy, expensive pieces of wood.
And all of these tools and the ones you listed have the purpose of enhancing the vocabulary of any impressionable youth that happen to be haning about.
Rob
A friend of mine who is a farmer always referred to an oxyacetylene cutting torch as a "smoke wrench". The only tool that will reliably 'loosen' a stubborn bolt on a tractor wheel.
And for the sciences:
WARNING: Please do not look into laser with remaining eye.
WARNING: Johnny jumped in the water, but Johnny isn't any more. For what he thought was H20 was H2S04. Don't be like Johnny, read the MSDS.
NOTICE: Do not 'goose' anyone with the Shop-Vac, there have been complaints.
NOTICE: Old Chinese Take-Away is not a proper experiment. Empty the fridge.
NOTICE: If you touch the optics, you clean the optics.
NOTICE: Professor Bunson Honeydew imitations are forbidden under penalty of wedgie.
Best Regards,
Bill Mattocks
I've heard of engineers labelling equipment too often moved by the janitorial staff,
"DANGER: 10,000 Ohms"
