back alley
IMAGES
in the standard mode view of the ovf...can i add just the histogram to it?
Glenn2
The last item on page 4 of the shooting menu is disp. custom setting. It allows you to choose the stuff you want displayed. OVF and EVF each have their own custom settings.
You lens hood should be there soon. I got a call Thursday (Victoria BC) that mine had just arrived.
Glenn
Glenn
willie_901
Yes,
Along with Glenn2's advice, set OVF Power Save mode to off.
back alley
IMAGES
Glenn
not sure what i'm doing wrong but this is not working for me...and willie , i have the power save mode off too...
back alley
IMAGES
very frustrating...i have only the histogram checked and i cannot get it to appear in the finder...
Gid
Joe,
The disp/back button cycles through the display modes - you have to set it to custom. It is set to standard by default.
back alley
IMAGES
it is set to custom...
sar-photo
Simon Robinson
Ok Joe - here's how it works on mine...
Go to DISP. CUSTOM SETTINGS
Select OVF
Check the settings you want i.e. HISTOGRAM
Exit from the Menu
When looking through the OVF press the DISP BACK button and you should see the display in the OVF change
Cheers
Simon
Select OVF
Exit from the Menu
Cheers
Simon
Gid
Select OVF
Exit from the Menu
Cheers
Simon
Agreed. I should have made it clear that you have to be looking through the OVF.
back alley
IMAGES
..When looking through the OVF press the DISP BACK button and you should see the display in the OVF change...
YES!!!!!!!!!!!!!!!!
the missing piece...
thanks!!
joe
YES!!!!!!!!!!!!!!!!
thanks!!
joe
