pairs of bodies
"Just trying to use multiple bodies rationally and effectively."
Is he referring to a couple of girlfriends?
Ted
FrankS said:
Looking at my RF gear, I can assign roles to particular pieces.
For example, I use B+W 400 speed film mostly (for its versatility) so I'll put it in the bodies I use most, currently the M6 and Hexar RF. These are used most because of the convenience of built-in meters. The M6 has a .85mag viewfinder so it's best with a 50mm lens (my fav. focal length, again for its versatility) while the .60mag Hexar is perfect for a 35mm lens.
My M2 and M3, I'll use for B+W 100 speed film for when I want less grain. A 50 on the M3, and a 35 on the M2, again due to their viewfinder magnifications.
This is of course, not set in stone, and I may use a 50 on the Hexar when I feel like AE with that focal length, or use 400 speed film in the M3 when low light focus accuracy is important.
The Contax IIa will sport a 50mm Sonnar f1.5, while the Contax II will host a 35mm J12 (which won't fit on the IIa) and an 85mm J9 to take advantage of the II's longer based RF. I'll use the Contax when I feel like a different feel than the Leicas.
Sound like a plan?
It sounds more like OCD 😀 (That's Overabudance of Cameras Disease 😀 😀 )
I like that.
I'm mostly working with two cameras in my bag. An M6 with DR Cron with the eyes attatched and a Kiev 4A with a J-8.
The M6 has color ISO 100 and the Kiev holds some ISO400 B&W.
If my evans walker bag was a little bigger I'd shove my CV 35/2.5 in the bag along with the bodies but alas it looked bigger in the picture
:bang:
I have my Yashica GSN loaded with ISO 1600 (too bad the ISO dial only goes to 1000).
It's all working out for me so far. I hope you plan works out for you Frank.
-Mitch
Biggles said:
I break CLs. I decided to buy another one in iffy shape and send it to Sherry Krauter for a complete spa treatment and cadmium disulphide colonic. When it comes back, if I drop the principal one again (Neopan 1600, 24/7), I'll have a spare available (also Neopan 1600) for follow-up dropping.
Nice one Biggles (or should I say Major James Bigglesworth? 😉 ).
I have two M7s which are unfortunately the same color and so identical (I am fixing that). In addition to this stupidity I have a not so smart strategy of carrying the same film in both. I usually have 400ASA in winter (HP5 & NP400) and 100ASA (APX100) in the summer in both cams. I am hoping to get a CV R4a this year sometime and that should screw everything up.
