oftheherd
Kim Coxon said:SMC = Super MultiCoated 😉 Early ones were labeled Super Multi Coated and had metal focus ring. Later ones were labelled SMC and had a rubber focus ring but they are effectively the same lens. They will work on the 705 but once on you won't be able to remove them! If you have no intention of getting an SPF or ES series, you can remove the full aperture pin and then they will work on all the M42 cameras including the SPF and ES series but the full aperture metering will be disabled.
Kim
I'm not at home to try, but what prevented them from being removed? I know there are tabs on the Fujica lenses both for registration and for the open aperture metering. I thought that I remembered that SMC lenses could be removed, but were just a little tricky. Was I just lucky? I think the only SMC lens I have is a 50mm f/1.8. All the lenses I normally use for the Fujicas are either Fujinons or Vivitar TX mounts.
