William: I've got the same 35/2.5 only in M39 mount. I had to go to Gandy's site to figure out what SC meant. So I assume it is on your Keiv 4A?
I had to stop for a moment when you said you couldn't understand the attraction of wide angles until you got the 35/2.5. Having used 28, 24, and 20 focal length lenses for so many years I didn't perceive the 35 as a wide angle. However, when I look through the viewfinder on my Bessa R and then through the viewfinder on my Yashica GSN....oh, yes, it is indeed a wide-angle, and probably a good one at that. Apparently your SC lens and my M39 lenses are optically the same (7 elements in 5 groups).
I have found the wide angles indispensible for architectural work (inside and outside) and for other situations where the 50mm doesn't cover the field you want to cover.
They can also become addictive. In my ex-Maxxum system I actually gave away the 50mm to my daughter when I realized I hadn't used it in 3 or 4 years. And of course, a week later regretted it when I needed it and discovered I had nothing between 24mm and 135mm.
