The best way I can describe it is like this. Think of the two formats like looking through two windows at the same tree. One of the windows is DX (cropped); the other is FX (24x36) full frame. Just because the tree occupies more space in the smaller window, it doesn't mean the tree is any closer. It just means there is less area around the tree compared to the big window (24x36).
Dear Frank,
True, and I've never seen why. Common experience: telephotos compress perspective, wide-angles stretch it.
That's the first thing in this discussion that I've managed to understand and agree with. Thanks for that simple answer.Roger said:Common experience: telephotos compress perspective, wide-angles stretch it.
Wouldn't it make more sense to talk about DOF in the print and not the film/sensor plane?
What we really REALLY want to know is whether depth of field changes on cropped-sensor cameras! :angel:
:bang::bang:
:bang::bang:
There seems to be a disconnect about perspective to those whose field is drawing and painting and whose field is photography and imaging. The standards in one field do not always translate to another. The Focal Encyclopedia of Photography, a fairly common and mundane source, covers the topic adequately.
Say you take photo (A) with a perfect 35mm lens. Then take photo (B) from the same viewpoint of the same object with a 50mm lens. WRT perspective, the outcome will be identical compared to a (A) cropped 1.4x, and in print enlarged by the same factor.
Why you like the same lens when moving from one format to the next, Joe, must have to do with the lens, not any photographic parameter, like FOV, perspective, etc 🙂
Roland.
Not really, perspective is perspective in both fields.
Maybe it's how we learn or use the term that causes confusion.
