I still shoot 8x10. Reasons? Tonality, resolution, contact printing, manipulation of the plane of focus (in all larger formats of course), etc.
Again, you are simply wrong. Here's the proof.
These were shot with a Nikkor 35mm f/2, 50mm f/1.8, and 135mm f/2. Each was shot at correspondingly larger apertures to match DOF - specifically the 35mm at f/2.8, 50mm at f/4, and 135mm at f/11. To match exposure, I changed only the ISO, which also gives slightly better image quality to help lessen the effect of cropping in of the shorter lenses (same reason why smaller sensors can give the same image quality of larger sensors when shot at lower effective ISOs).
Which is which? I simply matched exposure and also put on the proper lens correction profile so as to lessen the effect of distortion differences between these lenses, which is not in question. All were focused at the tip of the dog's nose. The only difference I can see is slight differences in contrast and color, normally attributable to small differences in any two lenses, not formats.
