jbielikowski
Jan Bielikowski
#181818 but black is not bad either.
You folks *do* realize a backlit screen is different than a reflected-light page of paper, right..?
Having a white screen will inevitably cause a (perceived) lightening of your image. Black on a computer monitor is colour-neutral and is faithful to the tones of your image.
If that kind of thing is considered important...
The problem is the eye is adaptive and an effect called simultaneous contrast can fool the eye into falsely identifying a tone as lighter or darker depending on the tone surrounding it.
if you care to follow this link:
http://www.pbase.com/mark_antony/image/70646869
You'll see that one of the brown squares looks a different colour because of the adaptive (local inhibition) effect.
Partly not so much with the TV (there are other reasons for that), but with respect to your question:
"surely by the time the light reaches the eye it's the same however it's been constructed?"
Is actually incorrect wrt to surround colour/density, what counts is in the processing by the brain.
Black surrounds give more tonal separation (in lower tones)and make colour easier to judge, white compresses lower tones.
... yes I understand that it is all perceptual, I did Rood and Munsell at college ... but then when I thought about it in order to be perceived as say "red" the light entering the eye must be the same wavelength and amplitude however it got there. no?
I've just been playing with a white screen, a piece of white paper and a desk-lamp ... and I not sure
No not quite. the wavelength is irrelevant to a degree, human perception is the key thing here.
So as you can see with the first colour image I posted the colour squares have the same RGB values, yet one looks darker-that effect happens in your brain, the light falling on your retina is exactly the same.
Here's a nice flash movie showing the effect in mono:
http://web.mit.edu/persci/gaz/gaz-teaching/flash/contrast-movie.swf
So yes the surround changes the perception of the density of the grey changes; and darker borders make lower tones easier to separate for the same reason.
You'll need to process your images to take that into account should you want to display on white.
Yes, as I said, I really do understand the concept of Complementary colours when used in combination, the concept of the natural order of colour, and persistence of vision. I also have a good grasp of gamut and contrast in visual perception.
I was musing on the implications of reflective and transmitted light to the viewer, and what if any impact that would have in designing a website from the viewers' POV
Is it possible (say with JavaScript) to allow the website viewer to select the background color?
Yes it's pretty easy, you can switch stylesheets dynamically, but I'm not a fan of these methods
Which I answered.
But again in case you missed it. A white background will compress the lower tones and favour the upper band, black will do the opposite, this will happen with both transmissive and reflective material, although the white background will make a much poorer matt for transmissive reproductions because of the overall lightening of mid tones ; that is subject dependent (which was answered in a previous post)
There is quite a bit of scientific material on this mostly citing movie and slide projection, and how having black borders or white changed the (perceived) tonal values. If you look at transparency sleeves for large format you'll see they are black–that is no accident.
So to recap
You will have to be mindful of the altering of (perceived) tonal values when using a sub optimal (for normal tones) fffff background, and process your images accordingly. Black backgrounds don't work so well with high key or predominantly light subjects, but are better for an average toned subject.
At least according to the science in the 'Theory of tone reproduction' but hey try putting them on a matt in PS see which you like, you may have to make two versions.
