pissed off
back alley
IMAGES
1:28 PM
i am really liking the 21 mm lens on my rd1 and the cv is a nice lens...small and sharp, easy to focus or just use hyperfocal distance method...but i want something faster...
like a 1.4 to expand usage...but who has that sort of cash to afford one?
not i...
Well .... you could spend your X100 budget on a Zuiko 21/2 with adapter; not a bad lens at all and you don't need RF coupling, do you ? :)
my x100 $$ was likely to be from selling one of the rd1s.
i would be hard pressed to sell one for a lens though.
A fast 21mm that doesn't break the bank? Now we just play the waiting game with Cosina, who knows what they'll surprise us with next.
Joe...as you know I'm using Al Kaplan's old Bessa-L body and got a 21mm f/4 CV lens from his son. That should be a lens that can be hand held at 1/15th sec which would with some care, press it close to your cheek and such, or at least 1/30th which would be an equivalent of f/2. I'm trying to practice some 1/15th shots inside the house, and we'll see how well I do. I can't justify the extra cost or size of an f/2 lens for a small camera.
Table Top Tripod.
Did somebody try to use a table tripod pushed on his chest?
Personnaly I shot like that with my 12mm f5.6 @ 1/15, even 1/8 with rather good results…
When I could also support my shoulder against a tree / wall, the results were even better.
A 12mm lens is just about the most un-critical lens you can get. It's so wide that you can shoot 1/15 handheld without a tripod. Subject motion is more of a problem.
Sorry I don't understand your message.
I was speaking about low-light situations, and I use the same technic with all my other lenses.
I only choose the 12mm as example because it's f5.6 (regarding the subject of that thread)
So : did you try that technic, with your 50mm or whatever?
Faster means bigger unfortunately. I don't use much the Elmarit 21/2.8 asph for this only reason.
holding a 12mm at 1/15 is the same (as easy) as holding a 50mm at 1/60 because of the FOV
Ok, Ok, you're right…
So, have you tried the above technique to get 1, 2 or 3 stops in low light situations with a 50mm or even longer lens?
There is a rule of thumb that short lenses are much easier to hand-hold than long ones. Usually we say that you can comfortably shoot hand-held at focal length X down to a speed of 1/X. So even shooting an 12mm lens at 1/8 is just like shooting a 50mm lens at 1/30, i.e. it doesn't really say much about the stability of the tripod.
I did and found it rather awkward. Among this kind of solutions I prefer a long piece of string attached to a tripod screw. However, tastes differ; one man's owl is another man's nightingale.
I find that in wideangles there is really no replacement for lens speed, (except maybe a camera with good high ISO capabilities ;)). The Summilux 21/f1.4 is one of the few Leica lenses that I'm seriously interested in.
