Plastic reel capacity
Takkun
Ian M.
1:59 AM
Sunny South Seattle
My first bulk-loaded roll I accidentally and absentmindedly loaded 45 exposures on it. I just now processed it, and it all fit on an Omega reel, thankfully.
Anyone know how much you can fit onto one?
Forty five frames is a lot of film in a cassette. Glad it worked out for you. I have never tried to load that many. I usually stop at 30 frames on the counter so I get around 24 to 26 good shots depending on the camera. This all fits perfectly with my Printfile negative pages.
I'm currently using Polypan F, very slim film base, but after 42-45 frames it is difficult, impossible to push it all into the reel. Cassette will take around 50 frames of Polypan F, no problem.
6 frames is normally the maximum in a regular sleeve. 7 rows so 42 you can still put in one sleeve.
But normally I am loading 35 frames, 7x 5 frames.
Thin layer (100um) Polyester 35 mm films:
Retro 80S, Retro 400S, Super Pan 200, ATP1.1, IR-400S. Polypan F is around 70um, a bit too thin .......
Efke 35mm films were also 100um Polyester.
I vaguely remember Ilford offering a (Jobo 1000/Patterson/Kindermann compatible) double capacity plastic reel when they introduced their 72 shot HP5 - apparently most people found other solutions, as few shops carried the reels after the initial hype.
