Please help me pull some TRI-X
capitalK
Warrior Poet :P
1:43 AM
Rookie mistake. I was shooting some film at ISO 64 then switched to TRI-X and didn't change the speed on my camera. I metered using the camera and didn't really notice until halfway through the roll because it was dark conditions anyway
So basically I need to pull this 2+ stops. I have Rodinal and HC-110 at my disposal. Anybody have any advice? It would be appreciated.
Use Rodinal stand development for 1 hour
1+100 agitate 1min at beginning and 20-30 sec mid time.
Will be grainy and dense, but usable.
Stand dev is your best bet in this situation. However, 2 and 1/2 stop over exposure is a lot.
According to the massive dev chart, D-76 w/ a 1:1 dilution will develop Tri-X 400 rated at ISO 50 in 7 minutes (at 20C).
No problem, you will have a very rich image, but you need to control those highlights.
I would try HC110 in dilution E (1+47) or F (1+79) - preferrably F -
E for about 5 minutes
F for about 8 min
Go easy on the agitation and say a good prayer not to blow those highlights
Times extrapolated from MDC and Covington's page
How about Microdol-X stock, at recommendet developint time it makes ISO 200, now if you shorten this time by 30 percent... you should reach ISO 100, which would only mean an overexposure by 1 stop.
Thanks, I think this is what I will try today. I'll post my results.
I have a very good push/pull chart which I have offered before. It was calculated by a previous chief film tech at a good boutique lab I used to work in. I don't know how to post it for down-load, but anyone who wants a copy can PM me and I will happily email a document.
BTW- Tri-X pulled to EI 64 should process nicely to give very good negatives. By and large, underexposure is a greater sin than over exposure. Anyway, it should be pretty easy to get decent results from this film.
I'd love to see that chart. I wonder if my PANF 50 could be souped in the same batch 1+100 @ 1 hour?
I developed 6 rolls in 3 diffferent tanks. My one roll at shot ISO 64 and my last two rolls shot normally turned out a little cloudy while my middle 3 rolls turned out perfect. These are the from the 64 roll.
Microdol-X is my go to for pulling- highlights don't seem to block up and grain is very tight.
I'll agree to watch the agitation- keep it gentle.
