crusius
Have you worked with DNG's? It should be apparent that they are not 8bit files. The compression does throw out some information, but they are not 8bit.
They are 8 bit. Non-linear 8 bit.
http://kammagamma.com/articles/solving-the-leica-m8-dng-riddle.php
This has actually been discussed to death. The DNGs are 8 bits and the highlights are a very problematic area whenever you want to do anything with them.
RD-1 files are quite useable in a number of circumstances, but if you are interested in wider angles, or faster lenses you are much more limited.
With my 12mm I think I get enough wide with the R-D1 🙄
Faster lenses are problematic to focus only if you print big, otherwise it is not such a big deal.
Like I said, I think that the M8 is better when printing big or cropping, but otherwise you'd be hard pressed to find fault with the R-D1.
I think my point here is: yes, the M8 is good, but the 8-bit issue is the only thing that allows one to say that it is not "better" than the R-D1. It is an astonishingly bad decision by Leica, one that they can still correct by firmware upgrade. If it weren't for that, then I think I could safely say that for all intents and purposes the M8 is "better." As it stands, it is more in the "it depends" class: if you do not want to print big, arguably you are better served by the R-D1 and its RAW files that give you more room for manipulation/correction.
