hughjb
This is a philosophical question, is a "point & shoot" a strip down range finder?
Huck Finn said:...A rangefinder is actually not exclusively a photographic instrument. By using the principle of triangulation, 2 separate images obtained at 2 different points can be used to determine distance &, therefore, in photography, accurate focus. Using a mirror & prism, the 2 images can be optically superimposed to find the precise point of focus...
Hmm...I don't know if RF lenses are actually optically superior. Some of the "recent" Leica M-mount lenses use the retrofocus design features of the SLR lenses.Huck Finn said:In either case, the use of a separate viewfinder allows the lens to be designed so that it is placed at the optimal distance from the film. In an SLR, the minimum distance is predetermined by the space required for the swinging mirror which provides for through-the-lens viewing. As a result, lenses for viewfinder cameras - including rangefinder cameras - can be designed smaller, & wide angle lenses, in particular, can be designed to be optically superior.
hughjb said:is a "point & shoot" a strip down range finder?
What they both offer is technically good exposures within their design limits without needing to know much about photography.
dmr436 said:A rangefinder, by definition (the way I've always understood it) uses the split-image triangulation method to determine the distance to the subject, which does require the photographer to perform the focusing function, either actively or passively (like setting to infinity or hyperfocal).🙂
This is a long winded way of saying it, but the rangefinder has to do with "range" or, an area of space that the selected lens will capture. The good RF user has to be able to see and decide upon what he will capture, based solely on the lens-lines in the viewfinder. Focusing is not the primary definition of an RF.
