laptoprob
back to basics
The 2nd swirly look seems like the 50/1,2. Could the other one be a CV Nokton?
I'd prefer a Sonnar I guess.
Assuming that both shots show the full frame, No. 2 is either a slightly longer focal length or you moved a little closer to the subject when you took the shot 😉
I'm guessing that No. 1 is the Heliar 50/2 and No. 2 is a faster lens, maybe 50/1.2?
The OP stated they are the same FL at the same apeture. The DOF is also very similar, not as different as a f/1.2 vs an f/2 lens would be.
Not unusual for there to be slight focal length differences, even between lenses that are nominally the same focal length.These shots were taken with the same film, in the same camera, mounted on a tripod and not moved between lens changes. You can actually see a slight difference in focal length even though they both claim the same focal length.
So I guess both lenses have the same maximum aperture as well as being shot at the same aperture (which was probably f2 since the OP has a Heliar), so I guess that removes the 50/1.2 from the selection.Both of these were shot wide open at the same aperture, same focal length. One is a Voigtlander lens and the other is not.
I prefer #2 mainly because the OOF highlights seem to be better controlled...
Dear Dave,I prefer - shaken, not stirred!🙄
but as a serious answer to a silly question - IMO they are both equally vile.
Dave.
I think the lenses are:
#1 35mm Nokton f1.4
#2 35mm Summilux pre-asph
