d 2 4 5 4 7 0 k
Hi chaps, thanks for taking the time to read this...
OK, so i have the above camera, and recently got it out to use it. The shutter won't fire. I have replaced the battery, and the meter works and moves as it should, but when the camera is cocked, it simply refuses to take a picture.
When i press the shutter release button, it goes down and comes right back up again. There is no click from the mechanism, and obviously no click from the shutter. Should the shutter release click regardless of the shutter blades opening or not?
Before i get the screwdrivers out, i need to know whether this is a classic case of the stuck shutter issue, which is prevalent in these cameras, or weather there is something missing in the chain of actions which should follow pressing the shutter release. incidentally, i also tried to set the self-timer, and flicking it into action does nothing. No ticking, no countdown...nothing at all.
I placed a battery in the camera, and the gauge in the RF window functions as it should, and the battery check light glows when the button is pressed, but the batteries did expire in '09', so do you think this may be a problem, and new batteries are required? Or would the camera fire without a battery anyway?
