Post Film Images Here
Zeiss 5cm 2
One "street" photograph from 2019:
M5 + Voigtlander VM 21mm 1.8 Ultron + Kodak Pro Image 100 [@80ASA]
So many different things in this picture, this is excellent. The 21mm length is very useful if used correctly. I am on the look out for a 21 zuiko but recently prices have climbed up so much.
Thank you Pan! Yes the 21mm is very useful in this situations.
I have a Zuiko OM 21mm 3.5 and I don't use it since I have the Voigtlander. The Zuiko is incredible good and small lens! If you want, I can leave it to you.
Shab, part of what makes this a great picture for me is that it has, as Pan says, many different areas of interest, people areas as well as spatial ones. Brilliant!
You and Pan are right, Anthony. I usually think "Less is more" and then I try to compose. But in this case I looked at the scene and I loved the complex situation: people areas, the first floor structures, converging in the infinity, the sun, the couple of women in the rocks... I loved the whole scene and as I had the 21mm in my camera, I decided to look at the best compo. I was there some time. I had a problem: this was the sun, because it wasn't in the same vertical line of the couple of women when I centered them in the compo. The sun was a bit to the right. Finally I thought "Ok, it isn't perfect but I will try it!" And then I waited for people's situation: the two women in the center, looking each other...
When I made the photograph I thought maybe it would be a "good" one, but I tried it. Now, when I have digitized it I've liked it so I decided to share with you.
Thanks for your words!
Thread viewers
