Praktina Spring Motor
Dez
Bodger Extraordinaire
8:18 PM
Mississauga, Ontario
I have a spring motor for my Praktina IIA, and while it seems to operate properly, I can't mate it with the camera. The drive cog on it has no kind of clutch, so it can't be made to line up with the female coupler on the bottom of the camera. I have seen a YouTube video showing the motor being installed which indicates that either the camera or the motor has some slip in the coupling to allow it to line up.
Anybody got some information of how to correct the situation? Like maybe technical information on the motor??
Dez
Dez
Hi Dez,
I don't have the spring motor for my pair of FXs yet (though I think they're pretty neat and would like one eventually). But I do have two genuine KW wind levers for them, which fit into the same drive keyway on the bottom of the camera body. I don't keep them fitted all the time but having used them and played around with them a bit I know that they are quite fiddly to fit into the socket. The threads are quite fine, much finer than one would expect for this sort of purpose on most cameras. Not only does the winder have to be perfectly aligned with the key in the camera but it must *must* be screwed into place perfectly parallel to the base of the body, otherwise the threads will not take.
With all this in mind, I suspect that you are going to have to (a) release the camera, and painstakingly wind it on until the angles of the drive key are perfectly aligned, and then, (b) very carefully lower the motor into place so that it drops in already parallel to the body.
Unlike most modern accessory pieces the Praktina ones won't self adjust as you fit them. This speaks to the precision with which they were manufactured, of course, but it is at the expense of being user friendly.
The last point is that those fine threads around the drive socket can be burred easily enough, they're probably in alloy. One of mine is quite hard or impossible to fit even a winder onto now, the other takes either winder without issue. It's possible there's a bit of thread damage on yours which is making it baulk as you try to fit the motor to it? Even if there's not, it makes the process of mounting the motor quite a painstaking one because if great care isn't taken, I could easily foresee the threads burring enough that in future, it would become impossible to fit it without getting the thread repaired.
So, no definitive answers above, sorry, but hopefully some clues that may assist.
Cheers
Brett
I just found my Praktina spring motor and following Brett's instructions, was able to connect it to a camera and make it function. Mostly. There is also an adjustment for the shutter release and I need to adjust that a bit. Wonderful old cameras and the 58mm f2.0 Biotar is a favorite lens of mine.
Thanks Brett.
Joe
Thanks Brett.
Joe
Happy to help Joe, its great to see another owner enthusiastic about these unusual but under-rated SLRs. I have only two lenses so far for my pair of FX Praktinas, but one of them is the 58mm Biotar (the other, a reasonably uncommon CZJ 80mm Biometar f/2.8). The Biotar is a good lens. I have it in Exakta bayonet and M42 as well, but I think the Praktina sample is the best performer out of those I have, from my results so far.
Brett
Even though this thread is somewhat dated, I wanted to comment on the Praktina line up of bodies, lenses, motors and winders. Especially after just reading Brett's review for the first time as like any collector of vintage cameras, at various times your interests peak on a particular camera in your collection.
This has happened to me with the Praktinas as I have been reading the various websites on line and thought I should be looking for a late model Praktina IIA to use some of the "Auto" lenses I have acquired over the last few years. I have two FX models and a IIA I purchased a few years ago. never did look at the serial # of the IIA until lo and behold it is in the 125xxx range which makes it one of the last IIA's manufactured. Solved my problem of having to acquire another body.
But, 2nd shutter curtain is fully closing at slow speeds, leaving a small slit on the left side. Most of the speeds from 125-1000 seem better but still the whole shutter seems sticky and dry. I think the curtains are OK (pinholes) but could be wrong on that.
Shutter repair ??? without sending to cupog as the shipping is costly???
Have lenses from 24/4 Enna, 25/4 Flektogon, 2-35's, 55 Steinheil, 58 Biotars, 75/1.5 Biotar, 80/2.8 Biometar, and 120 Biometar.... so a number, sold the 100 Trioplan for lots of money. Great German lenses which I also have for the 4-5 Exaktas I own.
Great system camera. Have a winder and spring motor. Motor works on one of the FX's but have not tried on the IIA with the shutter being messed up. Very finicky, I'll agree.
You might say, I've been into this system and after reading Brett's review (very nice by the way), I'll continue for awhile, until another of my collection draws my attention away.... for what ever reason.
Any shutter suggestions??
Regards,
Gary Hill
Regards,
Gary Hill
Hi Gary,
Thanks for the kind words about the review I wrote. Although the Praktinas were not at the top of my list of cameras to acquire I was well aware of them, so when a pair came up for grabs locally I took a punt on them on basic principles, because they each had a shiny Carl Zeiss Jena aluminium lens attached! And like you, I'm not averse to Exaktas or other unusual designs. They have absolutely exceeded my expectations. Not only are they a tactile delight because of the finish and solidity they possess, but I have also found them to be effective image making devices, and enjoyable to use ones, at that. But the best Praktina is one that is working well, because they are too good at making high quality images to idly languish in collectors cabinets. There are a few clues, I think, in my review about where to begin working on your IIA but I'll elaborate.
I do know that my FXs, both of which came from the same one-owner source were well cared for and not abused. Still, the curtain fabric on both of them is really good. Whatever material KW used is the stuff that Ihagee should have chosen for the Exaktas, I reckon, because mine have aged very gracefully indeed. If you think the curtains of yours look OK, they most likely are I expect. By all means, shine a torch at them in a dark room to check for pinholes though. Tip: wind the camera and then delicately depress the release, slowly, and you can flick the mirror out of the way to inspect the first curtain, as well as the second. And when you're using a Praktina, try to get into the habit of either keeping a cap on your lens or winding on immediately after exposure to protect the second curtain from sun damage. As you won't be able to use the (reflex) finder again until you've wound on, it's an easy habit to develop, I've found, but, as an Exakta owner, you're likely already on top of this, anyway.
Assuming they pass the light test and aren't particularly wrinkled, I reckon yours will just need to have the mechanism cleaned and lubricated, and possibly the spring tension boosted a click or two on the adjusters for the curtain tension. But maybe not: leave them well alone until the mechanism has first been serviced, because that may well be enough to see the curtains running nicely. Mine needed a slight adjustment to compensate for the loss of spring tension over the years, but it was minimal (a click or two at the most) and was only adjusted subsequent to servicing the mechanism. As the second curtain of yours is not quite capping off I suspect the tension will need a little help (adjusters are under the lower cover), but see how you go, first.
In terms of reaching the shutter spindles, this is just about as easy as on an old fabric shutter Praktica. Böhm used the same approach to constructing the rear of the Praktina body and the film rail plate is a separate piece that readily detaches after removing a few screws. You should keep the body face down, and be careful when lifting it up though, because the exact position of the plate relative to the lens mount determines the accuracy of the lens register to film plane, and there may be shims located under the rail plate. If so, you don't want them to fall into the mechanism, and you will want to note where each one is located before you carefully remove and label them, so that you can keep the register accurate on re-assembly. If there are no shims present, that is also OK, (unless, perhaps, you see signs of previous poor quality work such as butchered screw heads etc. which might raise the question of shims being lost or omitted). But let's not get ahead of ourselves.
With the plate removed you'll be able to readily access the spindles for the curtain shafts and take up spindles and a noticeable improvement in the alacrity with which the curtains move may well be achievable simply by irrigating these with small amounts of lighter fluid a number of times in between winding and releasing the camera. Although access is somewhat tight, the mirror actuating mechanism and some other components are all visible and accessible at least to an extent for inspection and cleaning if needed as well. You should particularly try not to get any solvent on the curtains or their tapes. You'd have to be very unlucky to create any issues as a result of a drop or two, but try not to get it near them, as it's possible it could damage the integrity of the adhesive bond between tapes and curtains or the tapes and their take up spindles.
Once you've cleaned and exercised the mechanism a number of times you will hopefully see the curtains running off a bit better. Particularly when you've just added some solvent to the spindle bearings. Any improvement will be temporary because the lighter fluid is not a lubricant. Well, I suppose it is (in the sense that it will help things move when it is freshly applied), but, it is volatile and has no staying power, so, once it's flashed off there's little residue, and what is left has no lubricant properties. So you should not be surprised if any improvement in functionality is only temporary and problems return the following day, once the solvent has flashed off. This is to be expected.
If you're using the correct minimal volume of naptha it shouldn't take that long, anyway, but you should certainly leave the camera with the plate and camera back removed to air for a few hours. You may then place minute specks of a suitable oil such as Nye oil or watch oil into the spindle bearings and exercise the mechanism again for a while, at which point, hopefully, the curtain accuracy will be improved. It's then time to check the speeds and only then, once you're satisfied the mechanism is clean and running freely you might want to fine tune the curtain tension a tooth at a time, re-checking the slit accuracy as you do. Less is more! If you're finding that a number of ratchet clicks are needed to obtain much, if any, increase in curtain speed, you probably don't have things cleaned and lubricated well enough. Keep a careful count of whatever adjustments you've made to each shaft in any case, so that you can retrace your steps and restore the initial settings, if needed.
I had the good fortune to acquire a rare and, (unsurprisingly, German language) copy of the factory repair and adjustment manual for one of the Praktinas last year. I can't recall which version(s) it covers offhand, but the shutter itself is common, or mostly common, to either sub-type and may be helpful (even more so, if your German is fluent no doubt!). If you run into problems, let me know and I can forward through a retrieval link to it, if you need it. Rick Oleson has some typically excellent notes on this SLR as well, if you get stuck.
Brett
Wow, now that's what I call a comprehensive response.
I'll try all of your suggestions as this seems very plausible and hope
this will solve the issues, even though I'll probably have to exercise the slow speeds in hope of maybe bringing them back. Getting into the escapement is going to be a bit more than I have talent for, but I'll see what happens. I also did contact Rick Oleson and got some fantastic repair diagrams.
Thank you, thank you, thank you for your interest and obvious expertise!
Gary Hill
