Oh my... I have a 2100, european version of 2200 that I use MIS UT (B&W) inks in.
It started by me leaving it unused for a couple of months, I was out traveling quite a lot and when I was home I did not really have time for it. Eventuelly I tried it and it was severly clogged. Cleaning cycles did not help.
I found some advice that soaking Isopropanol into a thick piece of cloth and tried it. It seemed to help and after that and two cleans, all channels were working. However, my happiness was short, some 15 A4 papers later (in just a couple of days) and it is clogged again.
I tried the Isopropanol again, and probably some 5 cleaning cycles, but my printer has now clogged up 3 channels out of 7 and I am getting quite desperate. One of the channels was low on ink, so I changed it, but no go, even after a couple of more cleaning cycles.
I have probably switched 7 cartridges during the last week.
Stupidly I thought I had it running and ordered 12 new cartridges for it yesterday, only to see the final clogging occur today. What a waste....
Now I am seriously reconsidering my approach to all this. I will take a serious thought about whether inkjets are anything to use at all. They are not cheap (mine was $1000 some years ago), I have probably spent $300-$500 so far on inks and $100-$200 on paper. I cannot really claim that I have gotten that many good prints out of it.
Do not get me wrong, it has produced nice results from time to time, but given the money and efforts sunk into it, I feel kind of tricked.
At some point one has to consider if there is any more point in sinking more money and efforts into it, or if I just should take it to the junkyard and get rid of all the troubles.
Problem is, what to do instead? For color I think the local Fuji lab has done a good job with my picture files. They can do B&W too that way, but it just does not appeal to me on these color-glossy papers, I like the results I got out of my darkroom better, especially the few I tried on fiber paper.
I guess I have to consider setting up a darkroom again, but there are both good and bad points with it.
+ Papers are at least as cheap, if not cheaper compared to inkjet.
+ Chemicals are probably way cheaper than ink.
+ I can leave it for months without any clogging, though I might need new chemicals.
- Requires space, and put aside time to print (planning).
- Cannot retouch and work with Photoshop. This is a major issue for me.
I guess that I have to give the printer another (final?) chance since I bought all that ink for it. Then I will make another attempt at printing B&W on the local color lab. I will have to take setting up a darkroom under serious consideration.
And finally, I would like to know if there is a good B&W printing solution out there that is not too expensive. The 2100/2200 has so far not been it for me.
When I see the price for the ink, it just pulls me towards the darkroom approach. On the other hand, I much prefer working with the computer...
Sigh..
Please give some advice on a good B&W printer that can sit unattended for periods of time, produce very good results and works up to A3+.
/Håkan
wtl said:
that's good news, Keith.
do you have any problem with head clogging on epson at all?
