david.elliott
Hello all,
The R3000 seems to be about $650 now and the 3880 is going for $900.
The R3000 is the newer product, but the 3880 comes with much more ink.
I plan to print both color and black and white 8x10 and maybe slightly larger.
Which printer would you recommend, and why?
Thank you for your assistance!
Best regards,
David
Best regards,
David
ChrisP
Grain Lover
Haven't tried both and I know this doesn't help much but I have a 3000 and it is fantastic, Don't know what else I could ask for in a printer except maybe to print bigger (13x19's don't look as big once they're on the wall). I would say it depends how much you plan to print each year. Bigger carts are a better deal if you're going to use them but if you won't print enough to use up all the ink than I believe they dry up over time.
david.elliott
Thanks for the input Chris. How many prints do you get out of a set of cartridges on the r3000? I don't anticipate making more than 100 prints per year.
dcsang
Canadian & Not A Dentist
David,
I have the Epson 3800 - the R3000 wasn't out when I purchased the 3800 some 3 years ago now I believe - I have yet to change a cartridge and the B&W prints (and colour for that matter) are sublime. My ink is currently "low" but it's only the "photo black" and, I think, the "light light black".
If you're not printing a huge amount on a regular basis (which would prompt me to suggest the 4800/4900 series) then, as someone who's used the 3800 for some time now, I would recommend it. 13x19 comes out wonderfully on this printer.
Dave
Dave
dasuess
Nikon Freak
I echo all the positive comments about the R3000. I've had mine for almost a month and have been amazed at the color prints it has turned out. I've done a few B&W, but have been concentrating on color. If you don't need bigger that 13x19, then the R3000 is a no-brainer. The only negative is the need to "manually" switch between PK and MK and the subsequent ink loss (about 1ml with each switch).
I am planning on using the Ink Supply (MIS) refillable carts with their K3 equivalent inks when the Epson carts run out.
hanzo
Its only from photo black to matte.. the other way around consumes 3 ml... ouch
But I like my R3000... so far
shiro_kuro
Charles Bowen
I have the 3880 and print out of Lightroom .The results are stunning . This is my first printer , it's amazing how easy it is to get satisfying results out Lightroom without much fuss ....
gavinlg
I'd go a canon 9000/9500 instead of the Epson due to repeated bad experiences with every single epson product I've ever owned.
david.elliott
But I like my R3000... so far![]()
Ouch, that is over 10% of the ink!
Under what circumstances does one have to make the switch one way or the other?
david.elliott
That is good to know. I have lightroom 3, but am likely upgrading to lightroom 4 in the near future.
david.elliott
Care to elaborate?
dasuess
Nikon Freak
Yeah, forgot that direction ;-) Which explains why my PK cart is really low, probably too low to make another switch without a new cart. But, to be fair, I have made the switch several times since getting the printer while trying out various papers I've had on hand. Should have thought ahead and planned those paper test a little better.
Ditto, though - I love this printer, for both color and B&W and will be ditching my Epson C88 with CFS set and EZ inkset.
hanzo
Its more than an ouch
Well, basically it depends on your choice of paper. For matte paper use matte black, and glossy paper photo black.
So you need to group your prints by paper type.
david.elliott
I'll stick to matte. Not too big a fan of glossy stuff.
Definitely more than an ouch.
Pablito
coco frío
I have owned maybe a dozen inkjet printers, probably more. Used heavily. The Epson 3880 is simply the best one I've ever worked with, MUCH better than any of the other Epsons and FAR FAR better than any of the Canons, which tended to clog up a lot more. The 3880 is a remarkable printer that not only produces stunning results but lets you change the ink cartridge mid-print! Currently, I have a 3880 in my studio and two more of them for my students.
sepiareverb
genius and moron
I too love the 3880, but have not used the R3000. Inks do last and last, I print a fair bit for various people and have only changed 3 cartridges over about 2 years. Likely 50% of the prints I've done (numbers not square inches) are 17x22"- I've gone through at least 150 sheets of that paper.
ray*j*gun
Hello all,
Best regards,
David
David, where are you seeing those prices? I'm in the market also.
Thanks!!
Bob Michaels
nobody special
Try Epson.com if in the US. Their current price for new 3000 is $650 with free shipping. $999 for refurbished (good as a new one) 3880.
I have always bought direct from Epson. I buy a refurbished unit when available.
Thanks!!
ray*j*gun
Thanks Bob!
dasuess
Nikon Freak
Ordered mine directly from epson.com and received it in less than a week as I recall. It's $650 after the $200 mail-in rebate and I'm still waiting for mine, but it's only been a few weeks since I sent it in.
