Problem with a Nikon FG....
Spider67
7:34 AM
Not a very big one. The ring that takes the prong from the lens sometimes sticks for example if I have f 4 and change to f 8, the camera's prong (don't know the English name for it) sticks at f 4 and will move delayd to f 8 sometimes mot at all.
Do you yhong a droplet of oil would be the cure or is it in need of a more sophisticated operation?
Best Regards
Des from Sunny and hot Rhodes
I would suggest, Bob, that the OP is referring to the meter coupling ring on the mount. I knew of an FE that exhibited a similar problem, but I never found out about the resolution...
You are correct, found out in a PM.
Bob
The ring gets dirty underneath, it needs to be removed and cleaned.
It's pretty easy to do as I recall, I forgot wher I read it... just google it.
A drop of oil will not help, it will make it worse.
Kiu
No suggestion on how to fix the problem but I did bring out my FG-20 last weekend and ran a roll of Reala 100 in it and just sent in the film today to the lab.... not one of Nikons best cameras I think but a robust old Nikon SLR... I use mine a couple of times every year just to "keep it going" !
Good luck with fixing yours!
Jon
