Problems with the strap lugs location in the bessas.
mdspace
6:27 AM
Japan - Mexico
Hi everyone, I think I'm not the olny one. 🙁
I bought a beautiful leather strap, this use to come with a ring in both sides, I fought to put them in my Bessa R2 and I finally did it, but I found that the feel of the camera was really bad, so I thought that the option was to put the rings in to the body attacheted in to de rings of the strap... but nothing changed.
Should I have to buy the hand grip to finally get the perfect ballance??? or should I think in another kind of strap.
Somebody has another wonderful idea? If someone have a good idea or simply can show me a picture of how you attached the strap to your body I will be really grateful.
Get a grip or use a heavier lens (like an Ultron or Nokton).
The location of the strap lugs on the Bessas suck ! The only reason
I can come up with, why they are where they are is the Bessa
heritage of Cosina bodies like the OM2000, where it made sense -
SLR lenses are bigger.
Roland.
You must get the grip, and for three reasons. First, the camera will hang properly, even with the light 35/2.5; second, the grip makes the camera a joy to handle; third, the grip protects the baseplate.
Yup, the grip really does help, doesnt hang percfectly, but works for me. Anyway, most of the time when actively shooting I wrap my neckstrap around my wrist and hold onto the grip.
Yeah, the camera tilts backwards unless you've got a hefty lens on the front, but it's not THAT much of a problem. I keep my Bessa R in the half-case for added protection, therefore not using a grip. It's mostly suspended from my right shoulder, or slung diagonally across the chest enabling the camera to rest under my right arm, and isn't really noticeable...It's not like you're carrying a huge SLR with a zoom...
At some point, I suppose they'll re-design the lugs, but maybe it's just another detail that lends some character to the line, eh?
Regards!
Don
I stole a wrist strap from my wife's Canon Powershot digital (actually she wanted lanyard type neck strap. The thin material easily passed through the right side strap lug. I now have a very light but secure wrist strap which I find very convenient. Dave
Regards!
Don
The balancing issue is really annoying to many users, like me. Fortunately, I put the strap across my chest from my right shoulder. That means, the camera is under my left arm. Anyway I could not use the grip as I have the leather case. Cosina should do some improvment here.😡
Luigi Strap
Luigi Strap
i noticed that too... i'm having Luigi make me a leather half-case with a built in side grip, and i'm having a custom strap made. it's basically a wrist strap that's a bit longer than a neck strap. that way, i can sling it over a shoulder and the camera will hang vertically from one lug rather than oddly balanced horizontally.
i'll post some pics when i get it.
cheers
b
Thanks!
Thanks!
Hi everybody😀 !!!
Thank you very much for all your comments and advises. I finally did it... somehow. The ballance still not perfect, but better now.
This is the picture of my Bessa...
Sienarot,
Unfortunately they don't make coloured grips, I painted. I really like the fix between same colour on the camera and the grip.
You just can find the trigger winder in olive or blue.
mdspace said:
Sienarot,
Well, you did a very good job then!
It's probably aluminum, so just weld on a plate of the same thickness and width, fashion in into the right shape, and paint it.
And, oh yes, do drill a space for the tripod. Better yet, install a tripod bush as some tripod fasteners may be too short to pass through the grip plate and still screw into the camera.
But what do I know, I was an English major in college.
