Chriscrawfordphoto
Real Men Shoot Film.
My better photographic projects are consistent subject/theme-wise and have a consistent "look". And, the consistent "look" comes from using the same equipment and materials through photograph the project.
For my photography, I can not achieve a consistent look across a project when I use result from different camera systems, e.g., digital, 35mm, medium format, and large format. My most cohesive projects, have a consistent pallet that results in a consistent look, which for me has meant using the same camera system, film, development, processing, and printing through the project. I also include lenses as a variable that affects the pallet, e.g., my large format Petzval lenses have a different look than my Heliar lenses, and my fish eye medium format lenses are inconsistent with my medium format portrait lenses for the same camera and by the same manufacture.
If you want to produce a single, quality body of work as your project, you are probably going to have to limit your equipment and materials for the project.
Best of luck to you in your project!
You'd be surprised how I've mixed gear in my long-term projects and no one noticed or cared. I usually try to keep to the same format (eg. 35mm or 6x6 or 645) in a project but I use different cameras. My Doll House project was partly done with Leicas and partly with Olympus OM SLRs. Why two systems? Cause a few of the shots needed a lens focal length that I don't have for Leica. I only have two Leica lenses but I have 15 OM lenses. I don't use most of them, I usually use 35, 50 or 85mm but I have others for when I need them. I needed a 28 for a few of the Doll pics and I have a 28 for OM.
