Purchasing a Training Camera For The Kiev Project
R
ruben
Guest
I would like to correct myself a bit regarding this issue. The camera that I recommend is the one identical or compatible with what you already have. If you have more than one, then purchase a camera identical or compatible with the one you like most.
Nevertheless this is not an absolute precondition. Your training camera can be whatever Kiev you want to use for the purpose.
My 'recommendation' just flows from the logics that once you become acquinted with the training one, it may be wise to have a replica of the same, also in the external parts. Secondly, it can happen that in case of purchase, the training one may come better than the one you already have. Thirdly to some degree, you may like to choose the best parts among the two. But all of this is quite secondary to having a camera for your training, you are ready to risk.
The issue of accepting the risk has a great psycological value, as you cannot enter a jungle by your own choise if you are full of fear.
Therefore, if you have just only one Kiev, but are ready to take the risk, this may be good as well.
Accordingly, today I ordered a 4am from Alex, as I have no camera I have not already opened. And I must feel and encounter the same as you.
Ruben
mike goldberg said:
Ruben,
There are many paths up the mountain to God.
~ Ancient wisdom from the Talmud
Cheers & good luck with your project,
Mike
Thank you
At a different level from a few in this issue, I am a pupil too.
And if we already climb to such phylosophical heights. let's not forget that no single big shot is better than a thinking team. This Kiev thinking team is what I am trying to spark here.
Against the mythical Hollywood and TV image of teams, in my opinion the most important is not high knowledge members, although they are necessary, but people with common sense.
Therefore, if the Kiev project will end as "my" project, the results will be rather limited. As I said before, no good will come from Amen choruses.
cheers,
Ruben
