johnastovall
Light Hunter - RIP 2010
tetrisattack said:X-rite color densitometers, gretag macbeth color checkers, calibrated imacon scanners, calibrated monitors, and custom ICC profiles for every paper they run through their printers.
The pros keep everything in control every step of the way through.
IR containation has nothing to do with color managment.
All of the above would just assure you got a correct magenta. The only solution is either an external IR Cut filter or a stronger one to start with on the sensor.
