brennanphotoguy
Tri-X @1600 looks awesome with DDX. I think I saw someone mention that up there somewhere as well. XTOL is great as well but comes with it's own set of challenges.
Because, in my case, I can use anything I want to develop film and I like the look I get. There has always been a sort of almost petty animosity directed towards Rodinal, possibly because of the stand development crowd, but I've seen some pretty amazing images from that method and those folks are happy with it. It's not for me but they like it. For example, Kodak themselves recommends no change in development for Tri-X when exposed at EI 800 rather than EI 400. In light of that does 2/3 of a stop actually mean anything at all outside of your own personal workflow?
With over 150 years of history do you really think Photography has or should have just a few ways of doing things? That's a little rigid, don't you think?
Thanks!
s-a
I don't know why Rodinal is used as a push developer. It's a speed losing developer, meaning you lose shadow speed rather than gaining it. Why not use a genuine speed increase developer like Microphen or DD-X, in order to pick up an extra 2/3 stop of shadow speed before cutting the exposure?
Animosity? I don't think I was the one directing any animosity. In fact I have nothing against Rodinal; I admire it for its gritty sharpness and gorgeous midrange tones, and have always kept some on hand. I don't think anything you said has anything to do with my question. I think you are throwing in the kitchen sink, without addressing anything I said. Kodak's recommendation for Tri-X in one of their own developers has nothing to do with Rodinal. And why bring 150 years of history into it?
I'm being rigid? No, I'm saying I simply don't see why one would use Rodinal for pushing, since it reduces the effective speed, rather than enhancing it, and there are better develops for the purpose. Apparently I'll have to wait for someone else to explain it.
My question was about Rodinal, it was not a personal attack on you. I believe you took it that way, and responded defensively.
I did not take it as a personal attack. OP wanted suggestions so I gave what I used. Your response was to question Rodinal's use to push. I was saying, in more than a text bite, that there are lots of ways to do development other than 'the usuals'. That's all. The history is pertinent to this. People getting upset about the whole Rodinal stand thing happens. No kitchen sink. Nobody was targeting you. Relax, I am.
s-a
Same here. Lovely tonality; beautiful sharp grain; lousy speed.Animosity? I don't think I was the one directing any animosity. In fact I have nothing against Rodinal; I admire it for its gritty sharpness and gorgeous midrange tones, and have always kept some on hand. I don't think anything you said has anything to do with my question. I think you are throwing in the kitchen sink, without addressing anything I said. Kodak's recommendation for Tri-X in one of their own developers has nothing to do with Rodinal. And why bring 150 years of history into it?
Dear Colin,Although on the topic of T-grain emulsions, Ilford's Delta 3200 is an ideal choice for you -- I've noticed it's a naturally lower contrast, perhaps to compensate for push-processing and its attendant increase in contrast.
For what it's worth, I've also had nothing but great results with their DD-X developer too, which is a great match not just for pushing but for that particular film, as well.
No. Monosize crystal emulsions (Delta, T-Grain) are NOT designed to push better.
A traditional cubic emulsion (Tri-X, HP5 Plus) in a speed increasing developer such as DD-X will work better.
Dear Colin,
Very true. I was thinking of slower films. Delta 3200 is a long-toe film that is especially designed for push processing; and which is indeed a bit muddy at its true ISO speed. typically 800-1200.
Tri-X in DD-X at 800, and sometimes at 1600 works well (for me).
T-grains are flat and about .166 - .142 the size of a conventional grain - allowing the emulsion to be thinner. Thinner emulsions have less light diffraction. The thickness is also affected by the lower thermodynamic reaction of the grains under development. The emulsion stays cooler (therefore stiffer) and does not allow the grains themselves to move, clump, and stack onto each other as easily. These properties are what give it increased sharpness and decreased grain.
Dear Rob,That was very clear! Now, how is the far smaller T-grain able to achieve the high sensitivity of, say, T-Max 400, Delta 400, Delta 3200? Is it possible that the light sensitivity is proportional to the frontal surface area, not the cubic volume of the grain?
And am I being proper to call the Ilford Delta films T-grain? I think they are a little different, somehow.
This comparison chart sounds very interesting but I wasn’t able to find it. Any specific terms I should search for?Kodak used to have a comparison chart online that rated four of their developers for fine grain, image sharpness, and effective speed.
