Bluesman
Richard
Guys/gals - what makes the Quickload mechanism scratch my film as it passes? For every perforation of the film, the film base (facing the back of the camera) gets a vertical band of scratches, 10mm high and 1 mm (or so) wide. The entire film is affected. Between perforations, the film is fine. Emulsion side looks fine to mee.
I guess it´s from the middle part of the QL mechanism "flap" - the middle steel tongue should tuck under one of the rolls/roller pins when the back closes. Mine obviously doesn´t do that properly and scratches film. Is this a case of too much pressure applied on the QL flap due to some light seal being too thick? The camera has had CLA by the previous owner and is top notch otherwise. This is the first roll thru it since I bought it.
Advice, please?
TIA & cheers /Richard
Advice, please?
